Support remotely connected dongles
It would be very useful if it is possible to select a remote USB zigbee dongle that is connected through ser2net. So instead of selecting a local USB port allow selection of ser2net connection simular as is done in the DSMR integration
This is available using Zigbee2MQTT.
I’ve thought about putting my server with the rest of my IT equipment and hosting DeCONZ and ZWaveJS on a little Pi somewhere central. It would be nice if there was a little Remote HAOS option, where you could install it on a Pi and make it super easy to connect to your main HA instance. I don’t want to spin up separate containers outside of Supervisor. Supervisor is so easy to use I’ve gotten soft.
That also exists.
