Hello, I have a Somfy curtains pilot which I would like to map in Home Assistant to control the curtains.
Somfy model is Somfy Telis 16 RTS
Somfy has their own protocol to control blinds called RTS, it uses a 433Mhz signal with a rolling code. The rolling code part makes it very difficult to duplicate - the remote is not sending the exact same code all the time.
You can use their Somfy myLink (end of life) or their current TaHoma Switch. There is a company called “Bond” that copies the rolling code. I would recommend using the Bond hub.
This is not true. The motor only has enough memory to be paired to 12 transmitters (remotes, wall switches, hubs, sensors, etc). Once you fill those slots, the motor will jog like it accepted the pairing process but will not move from the new transmitter. So the only time your remote will not work is if you reset the motor, erase all transmitters associated with the motor, delete the remote from the motor.
