Hello!
Can you help with a question?
I have the NodOn SIN-4-RS-20 which are called out as supported in 2023.11. However these devices are made for rolling blinds (up/down only) and don’t believe they really support tilt.
I now have 2 separate sliders - one of which doesn’t really do anything (the tilt).
Is there any way in the device or HASS settings I can remove the tilt slider?
Thx!
jhoff80
(Joe)
December 29, 2023, 7:30pm
42
Anyone figure this out yet? I’ve got 5 identical Ikea Fyrtur blinds. 1 of the 5 thinks it supports tilt even though it doesn’t.
Additionally I’ve got 2 of the Ikea Tredansen blinds, 1 of the 2 thinks it supports tilt even though it doesn’t.
All 7 of these run the same firmware version.
I know it is annoying, but until there is a better solution, tilt can be disabled using customize
: Disable tilt - #4 by julienhd
danist
(Daniel)
January 2, 2024, 12:05pm
44
Hi
The NodOn seems to support tilt. Because at least Zigbee2MQTT supports tilt for the NodOn SIN-4-RS-20 according to this
Therefore I assume the error must be elsewhere, either on your side or in the ZHA support for tilt.
I can confirm that ZHA tilt support for the Insta Nexentro Blinds Actuator Mini works. This device has been part of the same PR as the NodOn device:
home-assistant:dev
← tomasbedrich:tomasbedrich/zha-cover-tilt
opened 06:49PM - 15 Oct 23 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
This PR adds support to control cover tilt as defined in Zigbee Cluster Library Specification (rev 8) 7.4.2.1.2.9.
There are multiple devices waiting for this support:
- Ubisys J1
- NodOn SIN-4-RS-20
- [Insta GmbH Nexentro Blinds Actuator Mini](https://github.com/zigpy/zha-device-handlers/issues/1397)
This PR is a duplicate of #93301, which is currently stale despite our numerous attempts to contact the author @josef109.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Deprecation (breaking change to happen in the future)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: [zha-device-handlers#1397](https://github.com/zigpy/zha-device-handlers/issues/1397)
- This PR is related to issue: #93301
- Link to documentation pull request: <none>
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] I have followed the [perfect PR recommendations][perfect-pr]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone+-status%3Afailure
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/development_checklist/
[manifest-docs]: https://developers.home-assistant.io/docs/creating_integration_manifest/
[quality-scale]: https://developers.home-assistant.io/docs/integration_quality_scale_index/
[docs-repository]: https://github.com/home-assistant/home-assistant.io
[perfect-pr]: https://developers.home-assistant.io/docs/review-process/#creating-the-perfect-pr
So I guess it should be working on the ZHA side for NodOn.
Cheers
