Support Twilio API Keys
Twilio recommends using API keys as a more secure alternative to using account credentials.
This requires a small change to the Twilio API call to include the apiKey in addition to the accountSid (and replacing the accountSid auth_token with the apiSecret).
See this Twilio blog post for a fairly succinct explanation.
And the Twilio API key login documentation.
I believe this is the primary file that needs to be updated.
https://github.com/home-assistant/core/blob/3ecc914f290365b24724321221268b225f08c495/homeassistant/components/twilio/__init__.py
I thought about submitting this as an issue at github, but decided it is probably a feature request. I am happy to create the github issue if that is more appropriate.
If you know how you should submit a PR for the fix instead.
Hi Finity,
I don’t have a dev environment set up for making and testing changes.
If no one who maintains this integration want to make the fix, I may try to find time to get into it.
Fwiw, I think changing account_sid to username might be sufficient, but that would have to be done in a way that does not break things for existing configurations.
Cheers
