A common usage pattern for the serial integration is to define a serial sensor which contains a json blob or csv string value, and then define a template which extracts values as derived sensors.
However, it’s not possible to hide the source serial sensor entity because the sensor yaml configuration does not support setting unique_id.
This forum topic is a good example of the problem:
