I found this spanish review with the solution to this problem:
They say that you can edit database.db file to add some values to the correct place.
My problem is that my model is detected as “GL-B-008ZS” and not as “GL-B-008Z”. I edited the file to change that, and then is recognized, but if I unplug my lamp for some reason and plug it again, the bulb is rediscovered as “GL-B-008ZS” and device is not recognized again and I have to edit manualy the .db file again.
