Just dumping the config I used to integrate my Suprema Biostar fingerprint lock to my HASS
- platform: command_line
scan_interval: 3
switches:
bioentry:
command_on: 'curl -kX POST "https://172.16.0.19/api/doors/unlock" -H "accept: application/json" -H "bs-session-id: 270b8f4bd4664c2f90c57e1f97294c5b" -H "Content-Type: application/json" -d "{ \"DoorCollection\": { \"total\": 1, \"rows\": [ { \"id\": 1 } ] }}"'
command_off: 'curl -kX POST "https://172.16.0.19/api/doors/lock" -H "accept: application/json" -H "bs-session-id: 270b8f4bd4664c2f90c57e1f97294c5b" -H "Content-Type: application/json" -d "{ \"DoorCollection\": { \"total\": 1, \"rows\": [ { \"id\": 1 } ] }}"'
command_state: 'curl -kX POST "https://172.16.0.19/api/doors/status" -H "accept: application/json" -H "bs-session-id: 270b8f4bd4664c2f90c57e1f97294c5b" -H "Content-Type: application/json" -d "{ \"monitoring_permission\": true}"'
# command_state: 'curl -kX GET "https://172.16.0.19/api/doors/1" -H "accept: application/json" -H "bs-session-id: 270b8f4bd4664c2f90c57e1f97294c5b"'
value_template: '{{ value_json["DoorStatusCollection"]["rows"][0]["unlocked"] == "true" }}'
# value_template: '{{ value_json["x"]["Door"]["status"] == "2048" }}'
friendly_name: "BioEntry W2"
Hi
BioStar2 API
Home assistant Is it possible to control the door? Can you tell me in detail?
Yes its possible, the info in my post plus the biostar docs should be enough to get you going. If you cant understand at least that much then youll have a REALLY hard time if it breaks ![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=9)
Give it a go and let me know if you have any questions and I can try to help
/config/configuration.yaml
Can I only configure it here?
Does it automatically appear on the dashboard~?
That looks mostly correct, but dont forget to make sure its under switches!
When its configured you should get some new entities, you can check them under Developer Tools
Logger: homeassistant.components.command_line
Source: components/command_line/init.py:43
Integration: command_line (documentation, issues)
First occurred: ě¤í 1:06:13 (42 occurrences)
Last logged: ě¤í 1:18:31
ogger: homeassistant.helpers.template
Source: helpers/template.py:529
Error parsing value: âvalue_jsonâ is undefined (value: None, template: {{ value_json[âDoorStatusCollectionâ][ârowsâ][0][âunlockedâ] == âfalseâ }})
Timeout for command: curl -X POST âhttps://192.168.1.200/api/doors/statusâ -H âaccept: application/jsonâ -H "bs-session-id: f480f3ff93e14a969120253f50f68c7c " -H âContent-Type: application/jsonâ -d â{ âmonitoring_permissionâ: true}â
Maybe something with templates has changed⌠Iâll try and set things up again in a few days and try for you
