Sure petcare integration broken?
Hi folks,
I’ve noticed my sure petcare integration has not worked for two days. There were no errors in the logs. I’m running the latest version of the integration and home assistant.
I deleted the integration then attempted to re-add it but am met by the error “This integration does not support configuration via the UI. If you followed this link from the Home Assistant website, make sure you run the latest version of Home Assistant.”
Anyone else have this?
Now I’m at least seeing an error when I attempt to configure it
Error occurred loading configuration flow for integration surepetcare: No module named ‘custom_components.surepetcare.config_flow’
