It shouldn’t be any difference. As long as you are running Hass.io these instructions should work.
//Asif
Maybe it’s me or maybe 0.90.1 changed something in the custom components but I can’t get it to work
First of all, I had to add these lines before the new lines in __init__.py
import sys sys.path.insert(0, os.path.dirname(os.path.realpath(__file__)) )
Just so it would look for utils.py in the ~/.homeassistant/custom_components/sure_petflap/ directory
But that still doesn’t make the component work. I bugs out with the following error:
AttributeError: module 'custom_components.sensor.sure_petflap' has no attribute 'setup_platform'
Anyone any thoughts? (I cloned the repo today: March 24, 2019)
I can confirm that I my guide works with Hass.io version: 0.90.1 Running on RPI.
hmm, have you configured any template sensors etc?
Start with just setting up the surepet platform. Are you still getting that error?
Nope, no template sensore, binairy sensors, groups or anything.
Just:
- platform: sure_petflap
username: [email protected]
password: ******
I will retry all the steps from start and see if I made a mistake somewhere
Nope, redone the whole install according to the steps by @asif
The complete error from home-assistant.log:
2019-03-24 21:49:41 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform sure_petflap
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py”, line 124, in _async_setup_platform
task = async_create_setup_task()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py”, line 89, in async_create_setup_task
None, platform.setup_platform, hass, platform_config,
AttributeError: module ‘custom_components.sensor.sure_petflap’ has no attribute ‘setup_platform’
I tried manually running sp_cli.py which gave no issues at all
Could you upload all your files within the config\custom_components\sure_petflap folder?
Found my booboo… In my environment (virtualenv) custom_components is not located under config but directly under ~/.homeassistant and I had the directory sure_petflap located under custom_components/sensors in stead of under custom_components
Fixed my mistakes and now I have my Sure Catflap connected to HASS
Thank you! It works perfekt!
Härligt :)!!
Thanks for the write up, finally go this up and running in hassio. Can you give me some pointers as how to create a Lovelace card for individual items please or to see the list of items. ATM I can only see the list in devtools/States
The feeder arrives today!
I’ll let you know how it performs.
This is my config to setup the entities:
password: xxxxx
sensors:
jenna_status:
friendly_name: "Jenna Status"
value_template: "{{ state_attr('sensor.surepet_connect', 'Jenna') }}"
flap_battery_status:
friendly_name: "Sure Flap Battery"
value_template: "{{ state_attr('sensor.surepet_connect', 'battery') }}"
unit_of_measurement: '%'
flap_batterystatus:
friendly_name: Sure Flap Battery
value_template: >
{% if is_state('sensor.surepet_connect', 'unknown') %}
110
{% else %}
{{ states.sensor.surepet_connect.attributes["battery"] | float}}
{% endif %}
icon_template: >
{% set battery_level_xod1 = states.sensor.surepet_connect.attributes.battery|default(0)|int %}
{% set battery_round_xod1 = (battery_level_xod1 / 10) |int * 10 %}
{% if battery_round_xod1 >= 100 or is_state('sensor.surepet_connect', 'unknown') %}
mdi:battery
{% elif battery_round_xod1 > 0 %}
mdi:battery-{{ battery_round_xod1 }}
{% else %}
mdi:battery-charging-wireless-outline
{% endif %}
- platform: history_stats
name: Jenna outside time (today)
entity_id: sensor.Jenna_status
state: 'Outside'
type: time
start: '{{ now().replace(hour=0).replace(minute=0).replace(second=0) }}'
end: '{{ now() }}'
name: Jenna trips outside (today)
state: 'Outside'
type: count
end: '{{ now() }}'
name: Jenna outside (yesterday)
state: 'Outside'
type: time
end : '{{ now().replace(hour=0).replace(minute=0).replace(second=0) }}'
duration:
hours: 24
name: Jenna trips outside (yesterday)
state: 'Outside'
type: count
duration:
hours: 24
binary_sensor:
sensors:
lock_status:
friendly_name: "Sure Flap"
device_class: lock
value_template: "{{ not states.sensor.surepet_connect.attributes.locked}}"
icon_template : >
{% if states.sensor.surepet_connect.attributes.locked %}
mdi:lock
{% else %}
mdi:lock-open
{% endif %}
flap_status:
friendly_name: "Flap online Status"
device_class: connectivity
value_template: "{{ states.sensor.surepet_connect.attributes.flap_online }}"
icon_template : >
{% if states.sensor.surepet_connect.attributes.flap_online %}
mdi:wifi
{% else %}
mdi:wifi-off
{% endif %}
hub_status:
friendly_name: "Hub online Status"
value_template: "{{ states.sensor.surepet_connect.attributes.hub_online }}"
icon_template : >
{% if states.sensor.surepet_connect.attributes.hub_online %}
mdi:wifi
{% else %}
mdi:wifi-off
{% endif %}
And this is my Lovelace GUI:
Thank you Asif, I shell work my way through this as Im quite new to HA but learning fast, this helps a lot.
Sure/Absolut
These are the custom js and modules I’m using. Please google on how to add custom js and modules to your ui-lovelace.yaml
- type: js
url: /customcards/lovelace/card-modder.js
- type: module
url: /customcards/lovelace/circle-sensor-card.js
And here is the Code:
- type: vertical-stack
cards:
- type: custom:card-modder
style:
border-radius: 20px
border: solid 1px rgba(100,100,100,0.3)
box-shadow: 3px 3px rgba(0,0,0,0.4)
overflow: hidden
animation: '[[ sensor.flap_batterystatus.state ]] 2s linear infinite'
# animation: [[ if(sensor.washer_animation == 'Clean', "blink 2s linear infinite", "none") ]]
extra_styles: >
@keyframes 0.0 {
50% {
outline: 3px solid #389638;
card:
type: picture-elements
image: /local/images/jenna_inside.jpg
elements:
- type: image
entity: sensor.jenna_status
style:
top: 50%
left: 50%
width: 100%
state_image:
"Inside": /local/images/jenna_inside.jpg
"Outside": /local/images/jenna_outside.jpg
- type: image
image: /local/images/cat.svg?v1
state_filter:
"Inside": invert(.5) sepia(1) saturate(8) hue-rotate(10deg)
"Outside": invert(.90)
tap_action: more-info
style: {color: white, left: 10%, top: 88%}
- type: state-label
style: {color: white, left: 10%, top: 95%}
- type: state-icon
entity: binary_sensor.lock_status
style: {color: white, left: 25%, top: 88%}
- type: state-label
style: {color: white, left: 25%, top: 95%}
- type: state-icon
entity: sensor.flap_batterystatus
style: {--paper-item-icon-color: green, color: white, left: 40%, top: 88%}
- type: state-label
style: {color: white, left: 40%, top: 95%}
- type: state-icon
entity: binary_sensor.hub_status
style: {color: white, left: 70%, top: 88%}
- type: state-label
style: {color: white, left: 70%, top: 95%}
- type: state-icon
entity: binary_sensor.flap_status
style: {color: white, left: 90%, top: 88%}
- type: state-label
style: {color: white, left: 90%, top: 95%}
- type: horizontal-stack
cards:
- type: custom:circle-sensor-card
entity: sensor.jenna_outside_time_today
show_card: true
name: Jenna outside (today)
max: 24
min: 0
stroke_width: 7
gradient: true
units: 'H'
font_style:
color: white
font-size: 1em
fill: rgba(54, 128, 173, 0.23)
color_stops:
3: '#55FF55'
10: '#5555FF'
15: '#FF5555'
style:
top: 50%
left: 50%
width: 50px
height: 50px
entity: sensor.jenna_outside_yesterday
show_card: true
max: 24
min: 0
stroke_width: 7
gradient: true
units: 'H'
font_style:
color: white
font-size: 1em
color_stops:
3: '#55FF55'
10: '#5555FF'
15: '#FF5555'
style:
top: 50%
left: 50%
width: 50px
height: 50px
cards:
- type: entities
show_header_toggle: false
entities:
- entity: sensor.jenna_trips_outside_today
icon: mdi:chart-line
- entity: sensor.jenna_trips_outside_yesterday
Thank you!
Nice! Will this be read and write? So we can set the lock status from HA?
Anyone got pointers on getting this working with HA running in docker on Ubuntu ?
Not having any luck figuring it out.
Thank you so much!
