Not sure what changed but I now have
“Custom element doesn’t exist: surveillance-card.”
It was installed with HACS and I am currently on version 0.16.1
It has been running fine until I noticed it yesterday.
I updated to HA 0.101.1 this morning to see if that would help and it did not
I have uninstalled and reinstalled with HACS and still the same issue. Restarted HA in between and cleared cache.
19-11-01 13:55:26 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-01 13:55:26 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-01 13:55:26 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
Which I m pretty sure is unrelated.
in the Eventlog the only thing that might be related is
## Log Details (ERROR)
mb_type 4278 in P slice too large at 12 88
error while decoding MB 12 88
The camera’s are fine as I show them on two other views in different ways.
I assume from what you wrote that the surveillance-card is not showing up in the Developer Tools states tab. The plug-in code is showing up in the www/community directory as well as the resources: section for the ui right?
Reminds me of a wireless wall switch I have that is at the edge of the wireless signal area. Mostly I just get “can’t communicate” warnings in the log but on rare occasions the system will say the switch doesn’t exist. Then I need to use the native app for the switch to reset things. I think the switch goes into a captive portal mode and HA can no longer see it through the router. Typically requires multiple reboots of HA. Anyway glad you got it working!
