Im looking into some security IP cameras and wondered if this particular camera will work with Home Assistant/Hassio. Has anyone used these particular cameras? Thanks!
SV3C Security Camera, 1080P POE(Power Over Ethernet) IP Camera Outdoor, Home Security Surveillance Camera, 20Meter Night Vision, IP66 Waterproof, Stabler Connection Compared with WiFi Cameras
I Have a Synology NAS with Surveillance Station that manages the Camera and Home Assistant is able to pull the picture and video fine from Synology.
I did try to connect directly to the Camera from HA via ONVIF, but only got a static image. The Camera has a lot of different streaming options, so I am sure I could’ve made it work one way or another.
But you really need some kind of Network Video Recorder (NVR) to record and store the video, so if your choice of NVR is HA Compatible. you should be good.
Any NVR that supports ONVIF should be able to connect to the Camera.
