Kinda stoked, because I picked up this power strip off amazon for 25 bucks… (FCCID: 2AJK8-SWB1)
Was kind of a gamble hoping it was esp based, although I had seen other posts indicating could solder and flash, and was hoping this was the same model…
https://www.amazon.com/dp/B07MFTRMM3
Not only does it work great with ESPHome – but I was able to do OTA install using Tuya Convert, and got it up and running in a few minutes… (after using tuya convert to install Tasmota, just set it up in ESPHome, downloaded the bin, and uploaded via the Tasmota UI)
The button and light work with HA, but I didn’t set them up to do anything yet… Should probably add an on_double_click automation, but I’m not sure if I want it toggle all 4…
Anyhow, here’s the config I used:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Swb1-Power Fallback Hotspot"
password: "[redacted]"
captive_portal:
# Enable Home Assistant API
api:
ota:
logger:
# Device Specific Config
binary_sensor:
- platform: gpio
pin:
number: GPIO13
mode: INPUT_PULLUP
inverted: True
- platform: status
- platform: wifi_signal
name: "SWB1 WiFi Signal"
update_interval: 60s
switch:
- platform: gpio
name: "SWB1 Relay 1"
pin: GPIO12
- platform: gpio
name: "SWB1 Relay 2"
pin: GPIO14
- platform: gpio
name: "SWB1 Relay 3"
pin: GPIO15
- platform: gpio
name: "SWB1 Relay 4"
pin: GPIO5
light:
- platform: status_led
pin: GPIO0
