SWDK ZDG300 Mop Robot
Hello.
Is it possible to integrate the SWDK ZDG300 robot mop (Xiaomi ecosystem) in HA ?
I didn’t find anything about this device here.
I have successfully recovered the token (via VEVS Xiaomi Custom App).
Thank you in advance
afair i uses protocol bufferes packed into miio commands. integration should be doable.
Thanks, I’ll try this solution
Hi @jerryzz
I’ve tried to connect this robot to Mi Home but with no success.
It seems that’s wifi name of the robot is not recognized by Mi home (SmartLife-xxxx but the app is looking for kxf321-mop-mo001_miapxxxx).
Did you have the same problem ?
Thanks in advance
you don’t have mijia version. connect to smartlife app.
I am also interested in an integration.
I just bought a ZDG300 and I am waiting to receive it (global version)
Have yiu connected it to home assistant?
Does it allows for manual water pump?
no option for manual water pump via HA
