Sweep RGBW LED colors
After having looked for a script for sweeping through a range of colors and brightnesses on an RGBW LED strip, I found this post from @TheHolyRoger. Although it is very complete, it was lacking brightness adjustment, and also color ranges from -360 to 360, so that you could select (for example) a “red pallet” from -10 until 40.
blueprint:
  name: Fading Hue, Saturation and Brightness
  description: Gradually change light colour
  domain: script
  input:
    entity:
      description: Which entity to control.
      selector:
        entity:
    max_value_hue:
      name: Max Hue Value [-360:360]
      description: Max Hue Value
      default: 360.0
      selector:
        number:
          min: -360.0
          max: 360.0
          step: 0.1
          mode: box
    min_value_hue:
      name: Min Hue Value [-360:360]
      description: Min Hue Value
      default: 0.0
      selector:
        number:
          min: -360.0
          max: 360.0
          step: 0.1
          mode: box
    max_value_sat:
      name: Max Saturation [0:100]
      description: Max Saturation
      default: 100.0
      selector:
        number:
          min: 0.0
          max: 100.0
          step: 0.1
          mode: box
    min_value_sat:
      name: Min Saturation [0:100]
      description: Min Saturation
      default: 0.0
      selector:
        number:
          min: 0.0
          max: 100.0
          step: 0.1
          mode: box
    max_value_bri:
      name: Max Brightness [0:100]
      description: Max Brightness
      default: 100.0
      selector:
        number:
          min: 0.0
          max: 100.0
          step: 0.1
          mode: box
    min_value_bri:
      name: Min Brightness [0:100]
      description: Min Brightness
      default: 0.0
      selector:
        number:
          min: 0.0
          max: 100.0
          step: 0.1
          mode: box
    step_value_hue:
      name: Hue Step value
      description: Maximum random step value to change each time. [0:360]
      default: 30
      selector:
        number:
          min: 0.0
          max: 360.0
          step: 0.1
          mode: box
    step_value_sat:
      name: Saturation Step value
      description: Maximum random step value to change each time. [0:100]
      default: 30
      selector:
        number:
          min: 0.0
          max: 100.0
          step: 0.1
          mode: box
    step_value_bri:
      name: Brightness step value.
      default: 30
      selector:
        number:
          min: 0.0
          max: 100.0
          step: 0.1
          mode: box
    default_value_hue:
      name: Default Hue Value
      description: Default starting hue value.
      default: 0.0
      selector:
        number:
          min: 0.0
          max: 360.0
          step: 0.1
          mode: box
    default_value_sat:
      name: Default Saturation
      description: Default starting saturation.
      default: 100
      selector:
        number:
          min: 0.0
          max: 100.0
          step: 0.1
          mode: box
    default_value_bri:
      name: Default Brightness
      description: Default starting brightness.
      default: 100
      selector:
        number:
          min: 0.0
          max: 100.0
          step: 0.1
          mode: box
sequence:
- service: light.turn_on
    entity_id: '{{ entity }}'
    hs_color: "
      {% if state_attr(entity, 'hs_color') == None %}
      {{ default_colour }}
      {% else %}
      {% set rand_hue = range(-5000, 5000) | random / 5000.0 | float * step_value_hue %}
      {% set rand_sat = range(-5000, 5000) | random / 5000.0 | float * step_value_sat %}
      {% set cur_hs = state_attr(entity, 'hs_color') | list %}
      {% set cur_hue = float(cur_hs[0]) %}
      {% if cur_hue > max_value_hue and cur_hue - 360.0 >= min_value_hue and cur_hue - 360.0 <= max_value_hue %}
      {% set cur_hue = cur_hue - 360.0 %}
      {% endif %}
      {% set new_hue = cur_hue + rand_hue %}
      {% if new_hue > max_value_hue %}
      {% set new_hue = max_value_hue %}
      {% else %}
      {% if new_hue < min_value_hue %}
      {% set new_hue = min_value_hue %}
      {% endif %}
      {% endif %}
      {% if new_hue < 0.0 %}
      {% set new_hue = new_hue + 360.0 %}
      {% endif %}
      {% set new_sat = float(cur_hs[1]) + rand_sat %}
      {% if new_sat > max_value_sat %}
      {% set new_sat = max_value_sat %}
      {% else %}
      {% if new_sat < min_value_sat %}
      {% set new_sat = min_value_sat %}
      {% endif %}
      {% endif %}
      {% set new_hs = [new_hue, new_sat] %}
      {{ new_hs }}
      {% endif %}
    brightness_pct: "
      {% if state_attr(entity, 'brightness') == None %}
      {{ default_value_bri }}
      {% else %}
      {% set rand_bri = range(-5000, 5000) | random / 5000.0 | float * step_value_bri %}
      {% set cur_bri_abs = state_attr(entity, 'brightness') | int %}
      {% set cur_bri = float(cur_bri_abs) * 100.0 / 255.0 | int %}
      {% set new_bri = float(cur_bri) + rand_bri %}
      {% if new_bri > max_value_bri %}
      {% set new_bri = max_value_bri %}
      {% else %}
      {% if new_bri < min_value_bri %}
      {% set new_bri = min_value_bri %}
      {% endif %}
      {% endif %}
      {{ new_bri }}
      {% endif %}
    transition: 1.0
variables:
  entity: !input entity
  max_value_hue: !input max_value_hue
  min_value_hue: !input min_value_hue
  max_value_sat: !input max_value_sat
  min_value_sat: !input min_value_sat
  max_value_bri: !input max_value_bri
  min_value_bri: !input min_value_bri
  step_value_hue: !input step_value_hue
  step_value_sat: !input step_value_sat
  step_value_bri: !input step_value_bri
  default_value_hue: !input default_value_hue
  default_value_sat: !input default_value_sat
  default_value_bri: !input default_value_bri
  default_colour:
    - !input default_value_hue
    - !input default_value_sat
mode: single
Very nice thanks for the mention! Will have to test this out in place of my current blueprint :slight_smile:
