SwiidInter Cord Switch
Hello
After inclusion of a swiid swiidinter, I can change te state manualy, but there is no change in the UI.
If I change the state within home assistant, the light will go on. But when I than change te state when I press on the button of the swiddInter, the UI state of hass is still on, and the light out.
In the OZWCP, the state of the device change, even when I manually change it with the button.
Example: I change the state in OZWCP, the light will go on, I press the button, the light will go out, and the state in OZWCP will change too. This is how it needs to work.
the following text is in the manual of the swiidInter
WARNING : As with any Z-Wave®
“binary switch” device, the
SwiidInter™ is not able - for patent reasons - to report back
its status changes automatically to a Z-Wave®
controller.
The best way to monitor the change in status of your
SwiidInter™ in real-time is to associate via the second
association group (see Chapter on “Switch Association”)
with your primary controller. This works both when the
change in status of your SwiidInter™ is the result of a
manual action and when it is linked to a command
communicated through the Z-Wave® network. FOR CERTAIN
Z-WAVE® CONTROLLERS, THIS ASSOCIATION IS PRE-PROGRAMED
TO BE IMPLEMENTED ON ITS OWN WHEN YOUR SWIID® CORD
SWITCH IS FIRST INCLUDED INTO THE NETWORK.
But, in OZWCP it works lika a charm, thus there is notting wrong in the config of the z-wave network?
If i look at the zwcfg_*_.xml file, this is the node. Gist file on github.com
I can see that the association is there
I created a issue on the github issues tracker: github.com
Thank you!
I have created a gist with the OZW_Log.txt file from node 19 (Swiid Swinndinter) - click here for gist
After some more testing, i can say that it doesn’t work inside OZWCP. It only works, if the switch can reach the controller directly, if I put the light on the final destination, it doesn’t work any more.
Thus, i don’t know, if home assistant is’n translate the state change, when i press the button, correct or a problem with open-zwave.
It’s a another problem, i will create a new form post
quite old topic but here a question about swiidinter cord switch:
in general this switch is working great with HA at least the short press. I’d like to make an automation with the long press. any idea how I get this event?
I have moved across to use Zwave on my HA, from Vera, I cannot get the Swiid Cord Switch to join the Zwave network, how did you get yours to joing?
