Here you go!
I changed and few labels and reverted back to the original IP used by @cRemE-fReSh
"id": "653025e2b36a7e72",
"type": "tab",
"label": "CCEI Pool Light",
"disabled": false,
"info": "",
"env": []
"id": "ed0e528f.b8b9f",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
"id": "2bdc51a1b02b792d",
"type": "inject",
"z": "653025e2b36a7e72",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "60",
"crontab": "",
"once": true,
"onceDelay": "0",
"topic": "",
"payload": "",
"payloadType": "str",
"x": 110,
"y": 700,
"wires": [
"1f02efad119acce3"
"id": "1f02efad119acce3",
"type": "tcp request",
"name": "Pool Light",
"server": "192.168.188.13",
"port": "30302",
"out": "time",
"ret": "string",
"splitc": "0",
"newline": "",
"trim": false,
"tls": "",
"x": 280,
"y": 700,
"wires": [
"6c24733d447dba69",
"3e7d4d8388f3a8ad",
"79bfb8921557ef75",
"f4dfcb3c879f20c0"
"id": "6c24733d447dba69",
"type": "function",
"name": "Mode",
"func": "switch (parseInt(msg.payload.substring(64, 66), 16)) {\n case 0:\n msg.payload = \"Warm white (0)\"; break;\n case 1:\n msg.payload = \"White (1)\"; break;\n case 2:\n msg.payload = \"Blue (2)\"; break;\n case 3:\n msg.payload = \"Lagoon (3)\"; break;\n case 4:\n msg.payload = \"Cyan (4)\"; break;\n case 5:\n msg.payload = \"Purple (5)\"; break;\n case 6:\n msg.payload = \"Magenta (6)\"; break;\n case 7:\n msg.payload = \"Pink (7)\"; break;\n case 8:\n msg.payload = \"Red (8)\"; break;\n case 9:\n msg.payload = \"Orange (9)\"; break;\n case 10:\n msg.payload = \"Green (10)\"; break;\n case 16:\n msg.payload = \"Gradient (16)\"; break;\n case 17:\n msg.payload = \"Rainbow (17)\"; break;\n case 18:\n msg.payload = \"Parade (18)\"; break;\n case 19:\n msg.payload = \"Techno (19)\"; break;\n case 20:\n msg.payload = \"Horizon (20)\"; break;\n case 21:\n msg.payload = \"Hazard (21)\"; break;\n case 22:\n msg.payload = \"Magical (22)\"; break;\n default:\n msg.payload = \"Error\";\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 590,
"y": 680,
"wires": [
"701a9d39a26418fb"
"id": "3e7d4d8388f3a8ad",
"type": "function",
"name": "State",
"func": "msg.payload = parseInt(msg.payload.substring(33, 34));\n\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 590,
"y": 620,
"wires": [
"a4ab34733829f488"
"id": "79bfb8921557ef75",
"type": "function",
"name": "Brightness",
"func": "switch (parseInt(msg.payload.substring(71, 72), 16) / 4) {\n case 0:\n msg.payload = \"Low (0)\";\n break;\n case 1:\n msg.payload = \"Medium (1)\";\n break;\n case 2:\n msg.payload = \"Strong (2)\";\n break;\n case 3:\n msg.payload = \"Maximum (3)\";\n break; \n default:\n msg.payload = \"Error\";\n} \nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 610,
"y": 740,
"wires": [
"e8ec2211664323dc"
"id": "13e644bcb1f405df",
"type": "trigger-state",
"name": "Change Speed",
"server": "ed0e528f.b8b9f",
"version": 2,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityid": "input_select.pool_uws_speed",
"entityidfiltertype": "exact",
"debugenabled": false,
"constraints": [],
"inputs": 0,
"outputs": 2,
"customoutputs": [],
"outputinitially": false,
"state_type": "str",
"enableInput": false,
"x": 140,
"y": 340,
"wires": [
"43f0e3ec0de74f19"
"id": "43f0e3ec0de74f19",
"type": "function",
"name": "TCP Data",
"func": "var buffer;\n\nbuffer = msg.payload.split(\"(\");\nbuffer = buffer[1].replace(\")\", \"\");\nbuffer = parseInt(buffer);\n\nbuffer = \"{\\\"pspd\\\":\" + buffer + \"}\"\n\nmsg.payload = buffer;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 340,
"wires": [
"946ffd209f2589d8"
"id": "946ffd209f2589d8",
"port": "30302",
"out": "time",
"ret": "buffer",
"splitc": "0",
"newline": "",
"trim": false,
"tls": "",
"x": 580,
"y": 340,
"wires": [
"08c664f29688dc43"
"id": "c13865f1bab4b63e",
"name": "Change Brightness",
"version": 2,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityid": "input_select.pool_uws_brightness",
"constraints": [],
"inputs": 0,
"outputs": 2,
"x": 150,
"y": 400,
"wires": [
"cbf9337781a6d786"
"id": "cbf9337781a6d786",
"type": "function",
"name": "TCP Data",
"func": "var buffer;\n\nbuffer = msg.payload.split(\"(\");\nbuffer = buffer[1].replace(\")\", \"\");\nbuffer = parseInt(buffer);\n\nbuffer = \"{\\\"plum\\\":\" + buffer + \"}\"\n\nmsg.payload = buffer;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 400,
"wires": [
"320c9a6ab123939b"
"id": "320c9a6ab123939b",
"port": "30302",
"out": "time",
"ret": "buffer",
"splitc": "0",
"newline": "",
"trim": false,
"tls": "",
"x": 580,
"y": 400,
"wires": [
"08c664f29688dc43"
"id": "3da288b6630eb102",
"name": "Change Mode",
"version": 2,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityid": "input_select.pool_uws_mode",
"constraints": [],
"inputs": 0,
"outputs": 2,
"x": 130,
"y": 460,
"wires": [
"0672f5e12b9f5ed5"
"id": "0672f5e12b9f5ed5",
"type": "function",
"name": "TCP Data",
"func": "var buffer;\n\nbuffer = msg.payload.split(\"(\");\nbuffer = buffer[1].replace(\")\", \"\");\nbuffer = parseInt(buffer);\n\nbuffer = \"{\\\"prcn\\\":\" + buffer + \"}\"\n\nmsg.payload = buffer;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 460,
"wires": [
"74d1cbca96323148"
"id": "74d1cbca96323148",
"port": "30302",
"out": "time",
"ret": "buffer",
"splitc": "0",
"newline": "",
"trim": false,
"tls": "",
"x": 580,
"y": 460,
"wires": [
"08c664f29688dc43"
"id": "e8ec2211664323dc",
"type": "api-call-service",
"name": "Return Brightness",
"version": 5,
"domain": "input_select",
"service": "select_option",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "{\"option\":msg.payload}",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 790,
"y": 740,
"wires": [
"id": "f4dfcb3c879f20c0",
"type": "function",
"name": "Speed",
"func": "switch (parseInt(msg.payload.substring(70, 71), 16) - 4) {\n case 0:\n msg.payload = \"Slow (0)\";\n break;\n case 1:\n msg.payload = \"Medium (1)\";\n break;\n case 2:\n msg.payload = \"Fast (2)\";\n break; \n default:\n msg.payload = \"Error\";\n} \nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 590,
"y": 800,
"wires": [
"9f3ecb640de43ee1"
"id": "9f3ecb640de43ee1",
"name": "Return Speed 0",
"version": 5,
"areaId": [],
"deviceId": [],
"entityId": [
"mergeContext": "",
"queue": "none",
"x": 780,
"y": 800,
"wires": [
"id": "701a9d39a26418fb",
"name": "Return Mode",
"version": 5,
"areaId": [],
"deviceId": [],
"entityId": [
"mergeContext": "",
"queue": "none",
"x": 770,
"y": 680,
"wires": [
"id": "08c664f29688dc43",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "1",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 900,
"y": 380,
"wires": [
"fe5ff51ebae76e15"
"id": "fe5ff51ebae76e15",
"type": "switch",
"name": "",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 1050,
"y": 380,
"wires": [
"1f02efad119acce3"
"id": "000d8a4641390d36",
"type": "function",
"name": "TCP Data",
"func": "switch (msg.hassState) {\n case false:\n msg.payload = \"{\\\"sprj\\\":0}\";\n break;\n case true:\n msg.payload = \"{\\\"sprj\\\":1}\";\n break;\n default:\n msg.payload = \"Error\";\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 420,
"y": 280,
"wires": [
"f8f5516b6d29f601"
"id": "f8f5516b6d29f601",
"port": "30302",
"out": "time",
"ret": "buffer",
"splitc": "0",
"newline": "",
"trim": false,
"tls": "",
"x": 580,
"y": 280,
"wires": [
"08c664f29688dc43"
"id": "da6bf8763241ce21",
"name": "Return On",
"version": 5,
"domain": "input_boolean",
"service": "turn_on",
"areaId": [],
"deviceId": [],
"entityId": [
"input_boolean.pool_uws_powerswitch"
"data": "",
"mergeContext": "",
"queue": "none",
"x": 870,
"y": 620,
"wires": [
"id": "35ac253461f31dbb",
"name": "Return Off",
"version": 5,
"service": "turn_off",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"mergeContext": "",
"queue": "none",
"x": 870,
"y": 580,
"wires": [
"id": "a4ab34733829f488",
"type": "switch",
"name": "",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "else"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 710,
"y": 620,
"wires": [
"35ac253461f31dbb"
"da6bf8763241ce21"
"id": "f03c8b21d0bb3965",
"port": "30302",
"out": "time",
"ret": "string",
"splitc": "0",
"newline": "",
"trim": false,
"tls": "",
"x": 500,
"y": 200,
"wires": [
"e1b3f62c249b37b3"
"id": "e1b3f62c249b37b3",
"type": "function",
"name": "State",
"func": "var hassState = msg.hassState; //boolean\nvar wilState = parseInt(msg.payload.substring(33, 34)); //int\nvar setWilState = false;\n\nswitch (hassState) {\n case false:\n if (wilState == 2) setWilState = true;\n break;\n case true:\n if (wilState == 0) setWilState = true;\n break;\n default:\n}\nmsg.payload = setWilState;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 750,
"y": 200,
"wires": [
"76d180b9b220d258"
"id": "b17e808a337ccb24",
"name": "Change State",
"version": 2,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityid": "input_boolean.pool_uws_powerswitch",
"constraints": [
"targetType": "this_entity",
"targetValue": "",
"propertyType": "property",
"propertyValue": "",
"comparatorType": "is",
"comparatorValueDatatype": "str",
"comparatorValue": ""
"inputs": 0,
"outputs": 2,
"state_type": "habool",
"x": 130,
"y": 260,
"wires": [
"f3d34c92f7ff7d25"
"id": "f3d34c92f7ff7d25",
"type": "change",
"name": "C1",
"rules": [
"t": "set",
"p": "hassState",
"pt": "msg",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 250,
"y": 200,
"wires": [
"39035f85a63d3d83"
"id": "39035f85a63d3d83",
"type": "change",
"name": "C2",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 370,
"y": 200,
"wires": [
"f03c8b21d0bb3965"
"id": "76d180b9b220d258",
"type": "switch",
"name": "",
"rules": [
"t": "neq",
"v": "0",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 890,
"y": 200,
"wires": [
"000d8a4641390d36"
"id": "46835a02d54b28cc",
"type": "comment",
"name": "Comment compare states",
"info": "For On/Off it's required to check the original state of the device, because there's no separate on/off command but only a toggle command.",
"x": 310,
"y": 160,
"wires": []
