I can no longer swipe from the left to access the side bar on Android. Did something change?
+1. I have same issue. Any solution?
Same here and mentioned here too:
+1
It happened when I updated to the latest:
Home Assistant 2023.4.0
Supervisor 2023.04.0
Operating System 9.5
Frontend 20230405.0 - latest
I opened this ticket for Android - Edge Swipe for navigation drawer (2023.4+) ¡ Issue #3460 ¡ home-assistant/android ¡ GitHub. I donât know the full history, but it seems like previously the web front-end might have been handling the edge swipe gesture, but now it has been removed and possibly left for the native apps to implement themselves (also looks like it has already been done for iOS - Add edge swipe to show sidebar by bramkragten ¡ Pull Request #2328 ¡ home-assistant/iOS ¡ GitHub). Hopefully they re-integrate it; it seems like many people use this gesture frequently.
Yeah , especially when hiding the title bar, now I canât go to the menu anymore, I need to make buttons for it now, quite stupid
Having this problem on iOS too.
Ah looks like my app hadnât updated yet, had to go find it in the app store and click the update button.
Same here after update 2023.4.0 2023.4.1 and 2023.4.2
Just updated the mobile app but also no difference
Can you describe how to create these buttons? Is there a url or something else to open up the sidebar instead?
I donât know about a way to show the sidebar with a button but the âapplications/sectionsâ from the sidebar all have a unique URL like: âyour HA IP or name:8123/browser-modâ for instance.
When hovering above these buttons you see the URL and clicking the right button on your mouse can copy that link.
Then you create a button which navigates to that URL:
- type: button
icon: mdi:server
tap_action:
action: navigate
navigation_path: /browser-mod
Ok got it, thank you. 10 buttons for that workaround look really ugly
I hope the swipe function comes back soon.
I managed to get the sidebar to show via browser_mod.javascript service call.
Just add this to a button or an element on your frontend and when clicked it will show the sidebar.
There may be a more elegant way of doing this but it works.
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.javascript
browser_id: THIS
code: "document.querySelector('body > home-assistant').shadowRoot.querySelector('home-assistant-main').dispatchEvent(new CustomEvent('hass-toggle-menu', {detail: {open: true}}));"
Thanks a lot for that tip!
That doesnât work for my android. Event not in desktop browser. Everything is up to date. Browser mod is installed.
Doesnt work for me either
Does anything come up in console in DevTools??
Maybe one of my custom mods is causing my element selector to be differentâŚ
It basically just emulates the âhass-toggle-menuâ that i found under Event Listener in the browsers DevTools.
In your browser, while on your home assistant frontend. Go to DevTools and under the Elements tab.
It the âbodyâ section of the site, if you expand the first few sections there should be an element which contains the event to toggle the sidebar. If you right click that element then right click âcopyâ â âcopy JS Pathâ then put it into the javascript below and then into the tap_action as listed above.
"<PASTE_HERE>.dispatchEvent(new CustomEvent('hass-toggle-menu', {detail: {open: true}}));"
Thanks for your explanation but um stucked here:
Canât figure out event name.
//EDIT:
Ok, I was able to follow your instructions using chrome. But without success. I got the same code you posted.
Ok, my workaround is very simple. I just navigate to energy dashboard. There the button for the side panel is shown and I have access to everything again.
tap_action:
action: navigate
navigation_path: /energy
Perfect! I like your solution.
I prefer
navigation_path: /config/dashboard
because I use settings, automations or scripts more often.
