Switch a group error: Invalid config for [automation]: Entity ID group.tp-link is an invalid entity id for
I am going forward and backwards please can someone help:
My group won’t switch using my automation. I keep getting this error, Invalid config for [automation]: Entity ID group.tp-link is an invalid entity id. I don’t understand whay as i have created it as below.
Here is my code snippets I can manually switch the group in the overview.
group:
   tp-link:
    entities:
    - switch.Smartplug01
    - switch.Smartplug02
    - switch.Smartplug03
 automation:
   - alias: "Turn all lights on at 7:00am"
       platform: time
       at: '7:00'
      entity_id: group.tp-link
      service: homeassistant.turn_on
In the side menu of HA right down the bottom under Developer Tools, click on the <> icon. Look for what HA has renamed your group. It will probably be something like group.tp_link, or it may not be there.
HA doesn’t like dashes, I know you cant use them in script names. Probably the same for groups. Use underscores ( _ ) instead.
Thank you I will try this when I get home, :wink:
Thank you so much, that was it… I am so happy.
