blueprint:
name: Switch Allowance
description: Turns a switch off after an allotted time
domain: automation
input:
Switch:
description: This Switch will turn off after allowed time.
selector:
entity:
domain: switch
duration:
description: The amount of allotted time. (HH:MM:SS)
platform: state
entity_id: !input Switch
to: 'on'
for: !input duration
service: switch.turn_off
mode: single
It looks like this is just a normal switch template, not a lutron caseta specific one except for the name.
Edited it to be generic
Does this work for you? I get an error when trying to create an automation using the blueprint - it seems it’s trying to use a device_id rather than entity_id:
2020-12-19 15:39:03 ERROR (MainThread) [homeassistant.components.automation] Blueprint Change device status after period of time generated invalid automation with inputs OrderedDict([('trigger_time', '00:02:00'), ('trigger_device', '91a42907065311ebb26e3548969ee84c'), ('trigger_state', 'on')]): not a valid value for dictionary value @ data['action'][0]['entity_id']. Got None
L’ho modificato per entità light e funziona perfettamente.
