Hi. I have added a Sonoff th16 switch to a dehumidifier and I’ve been searching for a platform to use a Humidifier Entity but no one found so I’ve create one based on a switch and a humidity sensor. Also to be able to use with homekit.
It’s very simple and generic. I hope it can be useful to somebody.
Installation
- Copy all files in custom_components/switch_humidifier to your config/custom_components/switch_humidifier/ directory.
- Restart Home-Assistant.
- Add the configuration to your configuration.yaml file.
Usage
To use this component in your installation, add the following to your configuration.yaml file:
Example configuration.yaml entry
humidifier:
- platform: switch_humidifier
name: Switch Deshumidifier
switch_id: switch.deshumidifier
sensor_id: sensor.humidity
type: dehumidifier
Parameters
name
(Optional): The platform nameswitch_id
(Required): The switch entintity idsensor_id
(Required): The humidity sensor entintitytype
(Optional): Posible values arehumidifier
ordehumidifier
- Default:
dehumidifier
- Default:
It also support homekit.
Homekit
To use with homekit you need to especify the humidity sensor as linked_humidity_sensor
in the entity_config
homekit:
- filter:
include_entities:
- humidifier.switch_humidifier
- sensor.humidity
entity_config:
humidifier.switch_humidifier:
linked_humidity_sensor: sensor.humidity
