I have a few smart plugs hooked up to dumb electrical radiators, to aid the central heating system / reduce my gas usage (and better use the solar energy).
I can’t, however, set these to be a climate entity, which would ideally use temperature feedback from other sensors in the same zone to detect whether the target has been reached.
I’m doing this, but certain days i turn the climate Off. how can i make an automation that will turn the climate on into standby mode by itself in case i forget?
My furnace will trigger when temps are below x, but on days i leave my door open or doing stuff outside it might start running. So to prevent that I turned it completely off. Now if i forget to turn it back on it won’t trigger later at night if temps drops below X
It’s a bit off topic, but is your furnace controlled by HA?
If so… if I were you I would put contact sensors on all relevant doors/windows and configure a group for them which will show “open” if even one of them is open.
After that, you can refer to that in a condition in your automation to block execution if that group is “open”.
