Does it work when you trigger the automation manually?
Is the automation enabled? Meaning is it turned on when you check under Developer Tools-> States.
And I’d highly recommend changing the name of your switch, how can you work with this obscure name?
I didn’t think so either, Nick, so I removed it. I’ve also tried with and without the ‘ in the time. No luck. Tried other switches too and still not working.
Like Burning and Nick I’m a bit unsure what’s wrong here.
It’s obviously written by the GUI and you obviously need to rename your switch entity to make the automation functionality a little more obvious (switch.bfbc4c37057cb3c354huh7 to say switch.coffee_maker or whatever).
I will rewrite your automation in the traditional way and see if you have any better luck with that : -
no it was an hour out. That’s sorted it now. When I checked times in the logs earlier I didn’t spot they were an hour out as I assumed that was the time each event occurred.
How is HA installed.?
I’m assuming not with hassos ?
If so you need to correct your local time zone in the base OS.
If it IS hassos then you may have skipped a step during on boarding.
