Switch automation not working
I have a Tuya switch which is hooked up to the system and I can manually turn it off and on with the webapp.
I want to turn off the switch when my feed in tarif (FIT) goes negative. To do that I have tried the following :
  • Create a new device automation.
  • Trigger : when FIT < 0
  • Condition: none
  • Turn off the switch
When I test it, it doesn’t work. Even after rebooting the system. When the FIT < 0 the switch stays on.
Can anyone tell me what I am doing wrong ?
thanks
Matt
Share the actual automation, not a bullet-point description of it.
Post the automation in properly formatted YAML.
The following IDs have been modified by hand :
alias: "off: fit < 0"
description: ""
  - platform: numeric_state
    entity_id: sensor.sloane_feed_in_price
    below: 0
condition: []
  - type: turn_off
    device_id: 11111111
    entity_id: 22222222
    domain: switch
mode: single
Its ok - turns out the metric was in $ not cents !
