I’m strugling with implementing the following idea.
To give you a idea about the situation:
I have several RGB GU10 light pairs in my garden and these light pairs are mounted 1 up and 1 down. So i created 2 scenes that will do the following. 1 scene: upper lights red, lower lights green and second scene is inverted (up green, low red) Let’s name these scenes: RED_UP and RED_DOWN
Now i want to create a automation that will switch between these two scenes every 30 minutes (can be every time but for now 30 minutes) but only during a specific calender event: Christmas
Can anyone give me some guidance, examples or tips how to accomplish this?
Maybe i should step away from automation and scenes and use node red for this but in node red i also faced the same problem to get this setup working.
