Switch button witch triggers service calls
I’ve created two services calls which are running script remotly on a linux macchine (poweron and off).
Can i create a lovelace button with status on/off so it triggers on/off script.
yes.
go to config - automations - helpers
make a button helper
You have made this in the Node Red section, so I guess you are using Node Red.
Node Red should have HA entity nodes available and there is a button entity also, but since there are two scripts, then a HA switch node might be better.
That did the trick, thanks!
