Hello everybody,
I would like to ask for help, because I have no ideas where to go and I know that this is the ideal place to solve these problems
I use hassbian installed in a docker container on an Ubuntu machine and I am trying to create a command_line switch to send a command by ssh to the host machine.
If I run the command from the terminal on the host machine, it works, if I run the command from the docker container (HA) terminal it works … The problem is that I can’t get it to work via the command_line Switch.
switch:
- platform: command_line
switches:
record_uvc_sala:
command_on: "ssh [email protected] 'python /usr/share/hassio/homeassistant/python_scripts/REC.py'"
command_off: "ssh [email protected] 'python /usr/share/hassio/homeassistant/python_scripts/NOTREC.py'"
friendly_name: Gravação
And yes, I added the ssh keys to be able to access without entering a password.
