Switch configuring takes over 10 sec?
Hi I just put my home assistant config in new raspberry PI.
i use GPIO, and Broadlink, but now when I post the previously config I can’t run HA.
Please see config below.
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 53.175
longitude: 17.6167
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 107
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Warsaw
customize:
binary_sensor.motionsensor:
friendly_name: “MotionSensor”
device_class: “motion”
binary_sensor.noisesensor:
friendly_name: “NoiseSensor”
binary_sensor.lightsensor:
friendly_name: “LightSensor”
sensor.dht_sensor_humidity:
friendly_name: “Upstairs_Wilgotnosc”
homebridge_hidden: true
sensor.dht_sensor_temperature:
friendly_name: “Upstairs_Temperature”
automation:
  • alias: Turn off kitchen light 10 minutes after last movement
    platform: state
    entity_id: binary_sensor.motionsensor
    to: ‘off’
    for:
    minutes: 10
    service: homeassistant.turn_on
    entity_id: switch.nc_tv_power
  • alias: Turn on kitchen light when there is movement
    platform: state
    to: ‘on’
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
http:
Uncomment this to add a password (recommended!)
api_password: raspberry
Uncomment this if you are using SSL or running in Docker etc
base_url: example.duckdns.org:8123
Checks for available updates
updater:
Discover some devices automatically
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time.
history:
View all events in a logbook
logbook:
Track the sun
sun:
Weather Prediction
binary_sensor:
  • platform: rpi_gpio
    device_class: motion
    ports:
    17: NoiseSensor
    18: MotionSensor
    26: LightSensor
  • platform: dht
    sensor: DHT11
    pin: 4
    monitored_conditions:
    • temperature
    • humidity
  • platform: broadlink
    host: 192.168.8.127
    mac: B4:43:0D:38:48:C6
    • temperature
switch:
platform: broadlink
host: 192.168.8.126
switches:
tv_phillips:
friendly_name: ‘Tv Power’
command_on: ‘JgDaAJKTEjcTNhY0FRATEhEUERMTEhI3EzcUNBMTERQQExMTERMRExM2ExMRFBETEhISExEUETcWDhQ2EjgRNxM2EzcSNxMABfqTkxM2FDYSNxMTERMSExISEhQRNxI3EjcUEhISExIRExITEhQSNRIUEhITEhIUERISExI2FBIRNxI3EzcSNxI4EzUTAAX6lJQROBE3EjcTExEUEhISExMTETYUNRI4EhMTEhETExMSEhETEjYTExEUERMTEhETEhMTNRMTETcTNxM3EzYRNxM2EwAExQgAAlMLAA0FAAAAAAAAAAAAAAAAAAA=’
command_off: JgDaAJKTEjcTNhY0FRATEhEUERMTEhI3EzcUNBMTERQQExMTERMRExM2ExMRFBETEhISExEUETcWDhQ2EjgRNxM2EzcSNxMABfqTkxM2FDYSNxMTERMSExISEhQRNxI3EjcUEhISExIRExITEhQSNRIUEhITEhIUERISExI2FBIRNxI3EzcSNxI4EzUTAAX6lJQROBE3EjcTExEUEhISExMTETYUNRI4EhMTEhETExMSEhETEjYTExEUERMTEhETEhMTNRMTETcTNxM3EzYRNxM2EwAExQgAAlMLAA0FAAAAAAAAAAAAAAAAAAA=
nc_tv:
friendly_name: ‘NC Tv Power’
command_on: JgBQAAABLJQTNhM3FDcTExISExETEhM3ExITNhQ3FDYUOBISFDcSExMSEjcTExETEjcUEhMSExISNhYREjYUNxMUETcTOBM2FAAFAwABLEoSAA0FAAAAAAAAAAA=
command_off: JgBQAAABLJQTNhM3FDcTExISExETEhM3ExITNhQ3FDYUOBISFDcSExMSEjcTExETEjcUEhMSExISNhYREjYUNxMUETcTOBM2FAAFAwABLEoSAA0FAAAAAAAAAAA=
sony_blueray:
friendly_name: ‘BlueRay’
command_on: ‘JgCIAE4VJxEXEScVFBInExQTFBQUEhQTFBQUEicUExMoFBMAAr5PFSYTFRMmFBMTKBMUEhUTFBIVFBMSFhEoFRQRKBMUAAK/TxInFBMTKRMTFCYUFBIVEhUTFBIWERYRKRIUEycUEwACwU8TJhQTEygUEhMoFBURFhEUExQTFBUTFCcUExEpExMADQU=’
command_off: ‘JgCIAE4VJxEXEScVFBInExQTFBQUEhQTFBQUEicUExMoFBMAAr5PFSYTFRMmFBMTKBMUEhUTFBIVFBMSFhEoFRQRKBMUAAK/TxInFBMTKRMTFCYUFBIVEhUTFBIWERYRKRIUEycUEwACwU8TJhQTEygUEhMoFBURFhEUExQTFBUTFCcUExEpExMADQU=’
Use preformatted text when posting YAML. Also - if you’ve got an error in home-assistant.log, post that.
You might want to put single quotes round all of your broadlink commands.
