Or, if single execution is what you wanted, pick a previous automation trace to see what it was doing while it was triggered again.
EDIT: Having a 10 minute delay inside the automation that triggers every single minute is not something you’d want to do using queued or restart mode. It is a good thing you disabled that trigger. If you set queued, it will pile up fast. If you set restart, the 10 minutes will never finish.
So think on what you want to do during the multiple triggers, and consider using a timer and automations that run for a very short time. Using a timer you have full control of the actions after the delay.
Thank you. 1. The time pattern triggers every first minute of each hour. I disabled it to investigate why my two other triggers didn’t work. The 10-minute delay in the conditions was my attempt to mitigate rapid on/off behavior by the sensors, which can happen on sunny days with frequent cloud cover.
Is the real issue here that two of my triggers is executed the same time?
16:29 - If export is larger than import - Stopped because only a single execution is allowed
16:31 - If import is larger than export - Stopped because only a single execution is allowed
16:32 - If import is larger than export - Stopped because only a single execution is allowed
16:40 - If export is larger than import - Choose: Option 1 executed On
16:43 - If import is larger than export - Choose: Option 2 executed Off, delay 10 min
Thanks, everyone. I learned about IDs and realized what was likely halting my automation. I cleaned up the code using IDs and changed one of the triggers to a fixed value, which should prevent both triggers from running at the same time.
alias: Manage Floor Heating Based on Energy Prices and Solar Production
description: >
Turn on floor heating when prices are low (Q1), turn off during
overproduction, and turn off if no overproduction and not in Q1.
triggers:
- alias: If export is larger than 1.000W
trigger: template
value_template: |
{{ (states('sensor.ams_ec5d_po') | float(0)) > 1000 }}
- alias: If import is larger than export
trigger: template
value_template: >
{{ (states('sensor.ams_ec5d_po') | float(0)) <
(states('sensor.ams_ec5d_p') | float(0)) }}
- trigger: time_pattern
minutes: "1"
enabled: false
conditions: []
actions:
- choose:
- conditions:
- condition: trigger
id:
- enough_overproduction
- condition: and
conditions:
- condition: device
type: is_off
device_id: bdb56bab5f9ef9d9e0d4210ec044185f
entity_id: 10aa6676e1da35cc7b7327853c5c5938
domain: switch
sequence:
- type: turn_on
domain: switch
alias: Triggered by overproduction and Switch off
- conditions:
- condition: and
conditions:
- condition: template
value_template: >
{{ states('sensor.nordpool_energy_prices') | float(0) >
state_attr('sensor.nordpool_energy_prices', 'q2') | float(0)
sequence:
- type: turn_off
domain: switch
- delay:
hours: 0
minutes: 10
seconds: 0
milliseconds: 0
alias: Triggered by normal consumtion and high prices
- conditions:
- condition: and
conditions:
value_template: >
{{ states('sensor.nordpool_energy_prices') | float(0) <=
sequence:
- type: turn_on
domain: switch
alias: Triggered by normal consumtion and low prices
mode: single
