After upgrading HA to latest, zigbee lights work fine, but zigbee switch button presses don’t trigger their automations anymore. Zigbee coordinator is a ConBee II; switches are RWL-021 (four-button Philips Hue dimmers).
The automation is a simple one:
- id: '1589908124607'
alias: Turn on office light
description: ''
- device_id: bc9eb1b70a114cb7b0f3bdb4ca0f8dd8
domain: zha
platform: device
type: remote_button_short_press
subtype: turn_on
condition: []
- brightness_pct: 100
device_id: c907c3387ad34db09fedc687fbef27f2
domain: light
entity_id: light.office
type: turn_on
I’ve tried removing and re-adding the switches, and deleting and recreating the automations, with no effect.The automations themselves work if manually triggered… but the switches don’t trigger them.
On clicking one of the switches’ on-buttons, I immediately get the following in the debug logs:
2021-01-21 11:29:16 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|2: 170>, 0]
2021-01-21 11:29:16 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2021-01-21 11:29:16 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [26, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x5673>, 1, 260, 6, b'\x01+\x01', 0, 175, 199, 184, 243, 70, 0, -69]
2021-01-21 11:29:16 DEBUG (MainThread) [zigpy.zcl] [0x5673:1:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=43 command_id=1>
2021-01-21 11:29:16 DEBUG (MainThread) [zigpy.zcl] [0x5673:1:0x0006] ZCL request 0x0001: []
2021-01-21 11:29:16 DEBUG (MainThread) [zigpy.zcl] [0x5673:1:0x0006] No handler for cluster command 1
2021-01-21 11:29:16 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event zha_event[L]: device_ieee=00:17:88:01:08:6a:b0:f4, unique_id=00:17:88:01:08:6a:b0:f4:1:0x0006, device_id=bc9eb1b70a114cb7b0f3bdb4ca0f8dd8, endpoint_id=1, cluster_id=6, command=on, args=[]>
2021-01-21 11:29:16 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x5673>, ep: 1, profile: 0x0104, cluster_id: 0x0006, data: b'012b01'
If I’m listening for “zha_event” events at the time, I get this one:
"event_type": "zha_event",
"data": {
"device_ieee": "00:17:88:01:08:6a:b0:f4",
"unique_id": "00:17:88:01:08:6a:b0:f4:1:0x0006",
"device_id": "bc9eb1b70a114cb7b0f3bdb4ca0f8dd8",
"endpoint_id": 1,
"cluster_id": 6,
"command": "on",
"args": []
"origin": "LOCAL",
"time_fired": "2021-01-21T12:08:03.202650+00:00",
"context": {
"id": "697ec91fd2ec14f51ecd41585ded3a8a",
"parent_id": null,
"user_id": null
In fact, I can work around the problem by setting the zha_event as a trigger, manually filtering to that ID and command. But that really seems like a hack. Any idea why these events are getting so far, yet not being recognized as button presses?
This is a venv installation. Current pip package versions (tried to cut it down to the probably-relevant ones):
bellows 0.21.0
homeassistant 2021.1.4
zha-quirks 0.0.51
zigpy 0.30.0
zigpy-deconz 0.11.1
zigpy-homeassistant 0.19.0
