I have two generic thermostats which i would like to control with a switch. Basically i would like to use one switch to change the mode of both thermostats from off to heat. Seems simple but i cannot find a solution. Thanks for any help.
The turn_on and turn_off options can be lists of actions to perform.
Thanks for your help and the rapid response.
I don’t quite understand. I want to create a switch that I can include in a dashboard that will change the mode of two generic thermostats from off to heat. Below is the yaml; code for one of the thermostats:
# Office Fan heater
# HASSIO platform
- platform: generic_thermostat
# Thermostat name
# Switch entity to be controlled
heater: switch.office_fan
# Temperature sensor entity
target_sensor: sensor.lumi_lumi_weather_09c74404_temperature
# Set minimum set point available.
min_temp: 15
# Set maximum set point available.
max_temp: 17
# Set the switch specified in the heater option to be treated as a cooling device instead of a heating device.
ac_mode: false
# Set initial target temperature.
target_temp: 16
# Set a minimum amount of difference between the temperature read by the sensor specified in the target_sensor option and the target temperature that must change prior to being switched on.
cold_tolerance: 0.0
# Set a minimum amount of difference between the temperature read by the sensor specified in the target_sensor option and the target temperature that must change prior to being switched off.
hot_tolerance: 0.3
# Set a minimum amount of time that the switch specified in the heater option must be in its current state prior to being switched either off or on.
min_cycle_duration:
seconds: 5
# Set a keep-alive interval if required
# keep_alive:
# minutes: 3
# initial_hvac_mode: "off"
# Set the temperature used by preset_mode: away.
away_temp: 5
# The desired precision for this device.
precision: 0.1
You create the template switch and put it in your dashboard.
switch:
switches:
heat_mode:
friendly_name: Heat Mode
value_template: "{{ is_state('climate.your_first_one_here', 'heat') and is_state('climate.your_second_one_here', 'heat') }}"
turn_on:
- service: climate.set_hvac_mode
- entity_id:
- climate.your_first_one_here
- climate.your_second_one_here
hvac_mode: 'heat'
turn_off:
- entity_id:
- climate.first_one_here
- climate.second_one_here
hvac_mode: 'off'
I tried this:
switch:
switches:
heat_mode:
value_template: "{{ is_state('climate.office_thermostat', 'heat') and is_state('climate.office_fan_thermostat', 'heat') }}"
turn_on:
- entity_id:
- climate.office_thermostat
- climate.office_fan_thermostat
hvac_mode: 'heat'
turn_off:
- entity_id:
hvac_mode: 'off'
But I get:
Configuration warnings
Invalid config for 'template' from integration 'switch' at configuration.yaml, line 1 31 : expected a dictionary for dictionary value 'switches->heat_mode-
>turn_on->0->targetI, got [{'entity_id': ['climate.office_thermostatl, 'climate.office_fan_thermostat']}]
Invalid config for 'template' from integration 'switch' at configuration.yaml, line 139: expected a dictionary for dictionary value 'switches->heat_mode-
>turn_off->0->target', got [Centity_idl: ['climate.office_thermostatl, 'climate.office_fan_thermostat']}]
Once again many thanks for your help.
Thanks. Corrected the indentation but still got the same error!
switch:
switches:
heat_mode:
turn_on:
entity_id:
hvac_mode: 'heat'
turn_off:
entity_id:
hvac_mode: 'off'
Got there! Thats great, many thanks for all your help.
