McVillano
(Daniel)
September 21, 2018, 9:33am
1
Hello all,
I´ve just purchased a new Raspberry pi 3b+ and i was planing to upgrade my hassio instalation. Is it possible to just switch the sd card and start hassio on the new raspberry or i need to take a snapshot of the build, clean install and restore?
What do you think it would be better?
Kind regards
tom_l
September 21, 2018, 1:57pm
2
Not if you’re using the Hassio ResinOS image. You will have to build a new card from the HassOS image for the 3b+ and restore a snapshot.
McVillano
(Daniel)
September 21, 2018, 3:33pm
3
But acording to this image
The version for model 3b and 3b+ are the same. I guess i will test later, i have snapshots of the builds so if it gets wrong i can easily go back
tom_l
September 21, 2018, 3:54pm
4
That’s the HassOS image. I don’t think the ResinOS image was ever built for the 3b+. Have a read of the blog.
McVillano
(Daniel)
September 21, 2018, 8:34pm
5
Sorry i didn´t know there was a diference, i´m using HassOS image. So i´m going to try just switching and comment here with the results
what is the worst thing can happen?
tom_l
September 22, 2018, 12:22am
6
As you are using the HassOS image you should find it boots.
McVillano
(Daniel)
September 22, 2018, 4:46pm
7
I can confirm that the first boot took a little longer but it works flawlessly, also webpage works much more better in raspberry pi 3b +
M203
September 22, 2018, 8:41pm
8
Currently running HA on rasp model 3 b and looking to switch to 3b+. Hassio / HassOS. Just to confirm, you just took the configured sd card from 3b and put into 3b+ and it worked fine?
McVillano
(Daniel)
September 22, 2018, 8:57pm
9
Yes, first boot took a little extra and the page was trying to reload with an error but after 10 minutes i was able to log in and all was working
