in my config I use this switch, which works fine. After update to 2023.6 I get a warning, but I don´t really understand what to do
# Schalter
switch:
- platform: command_line
switches:
switch_keller_wwp:
command_on: "/usr/bin/curl -X GET http:/192.168.88.59/trigger:on:"
command_off: "/usr/bin/curl -X GET http:/192.168.88.59/trigger:off:"
friendly_name: Schalter WWP
This is the warning
Die Konfiguration der Kommandozeile switch mittels YAML wurde verschoben.
Konsultiere die Dokumentation, um deine YAML-Konfiguration auf den Integrationsschlüssel zu verschieben, und starte Home Assistant neu, um dieses Problem zu beheben.
Maybe sb can give me advice where I should put my config now
Best regards,
Stefan
