Interesting. I just got notified of an Update to 1.23 and will try again with that version.
Same issue with the new release. I enabled debug logging and got some errors.
File “/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py”, line 433, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: not a valid value for dictionary value @ data[‘entity_id’]
2023-09-09 15:40:52.508 DEBUG (MainThread) [custom_components.switch_manager.const] Running sequence for switch:0 button:0 action:0
2023-09-09 15:40:52.509 INFO (MainThread) [custom_components.switch_manager.const] switch_manager_0_0_0: Running switch_manager script
2023-09-09 15:40:52.509 INFO (MainThread) [custom_components.switch_manager.const] switch_manager_0_0_0: Executing step device automation
2023-09-09 15:40:52.510 ERROR (MainThread) [custom_components.switch_manager.const] switch_manager_0_0_0: Error executing script. Invalid data for device at pos 1: not a valid value for dictionary value @ data[‘entity_id’]
2023-09-09 15:40:52.512 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 1579, in async_run
return await asyncio.shield(run.async_run())
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 420, in async_run
await self._async_step(log_exceptions=False)
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 470, in _async_step
self._handle_exception(
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 493, in _handle_exception
raise exception
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 468, in _async_step
await getattr(self, handler)()
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 720, in _async_device_step
await device_action.async_call_action_from_config(
File “/usr/src/homeassistant/homeassistant/components/device_automation/action.py”, line 71, in async_call_action_from_config
await platform.async_call_action_from_config(hass, config, variables, context)
File “/usr/src/homeassistant/homeassistant/components/light/device_action.py”, line 76, in async_call_action_from_config
await toggle_entity.async_call_action_from_config(
File “/usr/src/homeassistant/homeassistant/components/device_automation/toggle_entity.py”, line 123, in async_call_action_from_config
await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 1935, in async_call
processed_data: dict[str, Any] = handler.schema(service_data)
File “/usr/local/lib/python3.11/site-packages/voluptuous/validators.py”, line 232, in call
return self._exec((Schema(val) for val in self.validators), v)
File “/usr/local/lib/python3.11/site-packages/voluptuous/validators.py”, line 355, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File “/usr/local/lib/python3.11/site-packages/voluptuous/validators.py”, line 351, in _exec
v = func(v)
File “/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py”, line 272, in call
return self._compiled([], data)
File “/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py”, line 818, in validate_callable
return schema(data)
File “/usr/local/lib/python3.11/site-packages/voluptuous/validators.py”, line 229, in _run
return self._exec(self._compiled, value, path)
File “/usr/local/lib/python3.11/site-packages/voluptuous/validators.py”, line 353, in _exec
v = func(path, v)
return schema(data)
File “/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py”, line 595, in validate_dict
return base_validate(path, iteritems(data), out)
