Switch not toggling correctly
I have a few tuya smart wifi switches incorporated into home assistant. Everything was working fine for a day or so, but today when I went to toggle one of the switches it just reverts back to its original state. Also, whenever I select the switch to look at it in more detail, it seems to have lost the cog button on the top right which would allow you to set the entity id and the friendly name. The switch works fine through alexa and the tuya app, it just seems to be in home assistant that the problem occurs.
I have included a video to show you what I mean. You will see that the other switch including fireplace works fineand has the cog button.
Any help would be greatly appreciated.
Cheers
Hey for me tuya is working correctly, but I made this account to say that the ewelink (public api?) is down, so ifttt/home assistant cant control ewelink/sonoff devices currently, itll probably be back up in a few hours. Seems this also happened around a year ago.
Hi. My tuya app is working fine. It’s just through home assistant they arn’t working.
Cheers.
