Switch not working in automation
I got an automation, but a simple rtf-switch is working on the front-end but not in the automation.
Probebly something simpel, but just can’t find the problem.
The second part, the Danfoss z-wave does work. so the problem shout really be somewhere in the automation of the switch.
This is my automation file
- id: 'cv_pomp_uitschakelen'
  alias: CV-pomp uitschakelen
  - at: '8:30'
    platform: time
  condition: []
    - data:
        entity_id: switch.d2
        service: switch.turn_off
  - service: climate.set_operation_mode
      entity_id:  climate.danfoss_z_thermostat_heating_1
      operation_mode: Heat
  - service: climate.set_temperature
      temperature: 16
I know that a don’t use the seconds in the trigger, but that I to be sure the rtf-switch gets the signal. (treid with the seconds, but no difference).
Maybe you have to use ‘08:30’ instead of ‘8:30’ - I think I’ve previously seen discussions about this.
But I use this format a lot and it works very reliably:
    platform: time
    hours: 07
    minutes: 01
    seconds: 00
The problem is not in the time.
The Danfloss part workshop on iT
Tanx anyway
Just saw it now, you have two ‘action’ sections and the spacing seems to be off.
    platform: time
    at: '8:30'
  condition: []
    - service: switch.turn_off
        temperature: 16
Thanx, already was thinking it had to do something with the spacing, but could not put my finger on it.
Now it works !
Good to hear - glad I could help.
