I bought this roller blind switch for our bedroom:
Unfortunately, the module’s LEDs are permanently lit, I would like to switch them off.
Does anyone know if that is possible.
Here are the data of the module (I have already successfully changed the time for an opening / closing from 100 to 130):
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.11.5",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.7",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "5.15.61-v8",
"supervisor": "2022.11.2",
"host_os": "Home Assistant OS 9.3",
"docker_version": "20.10.18",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"bosch_shc": {
"version": "0.4.36",
"requirements": [
"boschshcpy==0.2.37"
"hacs": {
"version": "1.28.4",
"requirements": [
"aiogithubapi>=22.2.4"
"alarmo": {
"version": "v1.9.6",
"requirements": []
"alexa_media": {
"version": "4.3.2",
"requirements": [
"alexapy==1.26.4",
"packaging>=20.3",
"wrapt>=1.12.1"
"enphase_envoy": {
"version": "0.1.2",
"requirements": [
"envoy-utils"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.34.4",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.87",
"zigpy-deconz==0.19.1",
"zigpy==0.51.6",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.3",
"zigpy-znp==0.9.1"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 27410,
"manufacturer": "_TZ3000_qqdbccb3",
"model": "TS130F",
"name": "_TZ3000_qqdbccb3 TS130F",
"quirk_applied": true,
"quirk_class": "zhaquirks.tuya.ts130f.TuyaTS130ESTC",
"manufacturer_code": 4417,
"power_source": "Mains",
"lqi": 223,
"rssi": -66,
"last_seen": "2022-12-05T16:39:02",
"available": true,
"device_type": "Router",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0203",
"in_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0x0006",
"0x0102",
"0xe001"
"out_clusters": [
"0x000a",
"0x0019"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"active_coordinator": false,
"entities": [
"entity_id": "cover.rollo_schlafzimmer_zemismart_zn_ec1c_tz3000_qqdbccb3_ts130f_cover",
"neighbors": [],
"endpoint_names": [
"name": "WINDOW_COVERING_CONTROLLER"
"name": "unknown 97 device_type of 0xa1e0 profile id"
"user_given_name": "Rollo Schlafzimmer Zemismart ZN-EC1C_TZ3000_qqdbccb3 TS130F",
"device_reg_id": "6a621547a7144c3d1bb3eeeed0dab986",
"area_id": "schlafzimmer",
"cluster_details": {
"1": {
"device_type": {
"name": "WINDOW_COVERING_CONTROLLER",
"id": 515
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {},
"unsupported_attributes": {}
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": null,
"attributes": {
"0x8001": {
"attribute_name": "backlight_mode",
"value": 0
"0x0102": {
"endpoint_attribute": "window_covering",
"attributes": {
"0x0008": {
"attribute_name": "current_position_lift_percentage",
"value": 100
"0xf000": {
"attribute_name": "tuya_moving_state",
"value": 1
"0xf001": {
"attribute_name": "calibration",
"value": 1
"0xf002": {
"attribute_name": "motor_reversal",
"value": 0
"0xf003": {
"attribute_name": "calibration_time",
"value": 145
"0xe001": {
"endpoint_attribute": "tuya_external_switch_type",
"attributes": {},
"out_clusters": {
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"242": {
"device_type": {
"name": "unknown",
"id": 97
"in_clusters": {},
"out_clusters": {
"0x0021": {
"endpoint_attribute": "green_power",
"attributes": {},
Greetings Werner
