Hi guys, I need to pull up a switch after a branch of and conditions, else switch off. I couldn’t write it right.
could somebody help me with sintax?
I write it as:
binary_sensor:
- platform: gpio
pin:
number: D1
mode: INPUT_PULLUP
name: "Porta Ingresso"
device_class: door
- platform: gpio
pin:
number: D2
mode: INPUT_PULLUP
name: "Finestra Soggiorno"
device_class: window
- platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
- platform: gpio
pin:
number: D7
mode: INPUT_PULLUP
output:
- platform: gpio
pin: D3
inverted: True
- platform: gpio
pin: D4
inverted: True
- platform: gpio
pin: GPIO1
inverted: True
switch:
- platform: output
name: "Inserimento Parziale"
output: 'inserimento_parziale'
- platform: output
name: "Perimetrale Soggiorno"
output: 'perimetrale_soggiorno'
- platform: output
name: "Disinserimento Antifurto"
output: 'disinserimento_antifurto'
- platform: gpio
pin: D4
#automazione perimetrale soggiorno#
esphome.on_loop:
then:
if:
condition:
and:
- binary_sensor.is_on: porta_ingresso
- binary_sensor.is_on: finestra_cucina
then:
- switch.turn_on: perimetrale_soggiorno_ok
but i get this on validate:
INFO Reading configuration /config/esphome/test.yaml...
ERROR Unexpected exception while reading configuration:
File "/usr/local/bin/esphome", line 11, in <module>
load_entry_point('esphome', 'console_scripts', 'esphome')()
File "/opt/esphome/esphome/__main__.py", line 566, in main
return run_esphome(sys.argv)
File "/opt/esphome/esphome/__main__.py", line 544, in run_esphome
config = read_config()
File "/opt/esphome/esphome/config.py", line 808, in read_config
res = load_config()
File "/opt/esphome/esphome/config.py", line 668, in load_config
return _load_config()
File "/opt/esphome/esphome/config.py", line 656, in _load_config
result = validate_config(config)
File "/opt/esphome/esphome/config.py", line 440, in validate_config
component = get_component(domain)
File "/opt/esphome/esphome/config.py", line 171, in get_component
assert '.' not in domain
AssertionError
please hep me…thanks a lot.
