I have been prototyping my new HA deployment, and am using a lot of ESPHome driven hardware. The topic here is about the Sonoff switches, and using them to turn loads on from HA.
I am planning a new build, and therefore have full flexibility to do what I want to do.
I have an AV and electrical room, which is where my Dell server resides, with all of the electrical, connectivity, Unifi setup, etc.
I am running all loads to that room. So all lights are going back to the room into an electrical box. In the electrical box, I will put the Sonoff switches.
Now I need to control those switches to turn lights on and off.
I can use my phone, a tablet, etc. but I need to have controls for the light where you would expect them. By the doors, etc so if someone is walking into a room, they have a switch to turn the light on. The “old” way. Some areas have 3-6 circuits. Large garage…
I am a hardware designer, so here is the diagram I am thinking about using. I have prototyped it already and got it working. Now I am thinking about making a custom PCB.
Here is the block diagram:
Some more details:
- There will be 8 touch. I need to optimize the connections a bit to get more touch sensors. In my POC, I have 7 now. The number of touches will change (up to the 8 ESP32 supports), but exact number will be driven by the IOs available.
- eInk, 2.90in display. The intent for that is to display the function of each button. So it is customizable. The button can turn on and off a light, an automation, or anything in between.
- I want to have a LED for each button for status. I thought about a single on/off LED. That would be the simplest as they make them bottom mount on the PCB. But to get fancy, I can add a WS2812b LED to each of the buttons, and control the color based on what i want, or could be as simple as on/off with a specified color. That makes the hardware a bit more challenging as it will be manual to mount the LEDs through the PCBs when they are not designed for that. Other alternative is to make a second PCB to solder the LEDs on, and put it behind the main one. I will decide on the mechanical design later. I will focus on function for now, so the intent is WS2812b for each button. Controlled as segments of 1 LED each.
- A PIR so I have presence in the room where the switch is, and I will use it to lower the dimming or turn the LEDs off
Questions…Is this thing even useful? Or is there an off the shelf one I can use. I don’t want to reinvent the wheel.
what am I missing?
Anything else you think I would need?
Anyone interested? My intent is to make it open source anyways.
Thoughts welcome!
H
