Hi Guys,
Build a simple blueprint that switches a input_select
to a specific state so you can switch the lights!
blueprint:
name: Verlichting op lichtsterkte
description: Laat een input_select de verlicht inschakelen of uitschakelen aan de hand van een behaalde lichtsterkte.
domain: automation
input:
lux_sensor:
description: Sensor die de lichtsterkte registreert.
selector:
entity:
domain: sensor
device_class: illuminance
switch_on_sensor:
description: Sensor die de inschakelwaarde bepaald.
selector:
entity:
domain: input_number
switch_off_sensor:
description: Sensor die de uitschakelwaarde bepaald.
selector:
entity:
switch_helper:
description: Sensor die geschakeld moet worden aan de hand vand de lichtsterkte.
selector:
entity:
domain: input_select
hysterese_duration_on:
description: Hysterese in minuten voordat programma wordt ingeschakeld.
default: 2
selector:
number:
min: 1.0
max: 15.0
unit_of_measurement: min
mode: slider
hysterese_duration_off:
description: Hysterese in minuten voordat programma wordt uitgeschakeld.
default: 5
selector:
number:
min: 1.0
max: 30.0
mode: slider
- platform: numeric_state
entity_id: !input 'lux_sensor'
for:
hours: 0
minutes: !input 'hysterese_duration_on'
seconds: 0
below: !input 'switch_on_sensor'
enabled: true
alias: Inschakelen
for:
hours: 0
minutes: !input 'hysterese_duration_off'
seconds: 0
above: !input 'switch_off_sensor'
alias: Uitschakelen
condition:
- condition: not
conditions:
- condition: state
entity_id: !input switch_helper
state: Uitgeschakeld
- choose:
- conditions:
- condition: trigger
sequence:
- service: input_select.select_option
option: Inschakelen
- conditions:
sequence:
option: Uitschakelen
mode: single
