seems that the filerights from the file /home/mgranger/.homeassistant/switches.db are not enough for the appdaemon user.
the appdaemon user has probably no writing acces in the dir where you want the db created.
Thanks for replying @ReneTode I solved by introducing a terminate function closing the db
Here is the updated code
import hassapi as hass
import shelve
# App to reset input_boolean, input_select, input_number, input_text to previous values after HA restart
# Args:
# delay - amount of time after restart to set the switches
# Release Notes
# Version 1.0:
# Initial Version
class SwitchReset(hass.Hass):
def initialize(self):
self.log_notify("SwitchReset Started")
try:
self.device_db = shelve.open(self.args["file"])
except:
self.log_notify("Could not open db")
self.log_notify(self.device_db)
return
self.listen_event(self.ha_event, "plugin_started")
self.listen_event(self.appd_event, "appd_started")
self.listen_state(self.state_change, "input_boolean")
self.listen_state(self.state_change, "input_select")
self.listen_state(self.state_change, "input_number")
self.listen_state(self.state_change, "input_text")
def terminate(self):
try:
self.device_db.close()
except:
self.log_notify("Could not close db")
return
def ha_event(self, event_name, data, kwargs):
self.log_notify("Home Assistant restart detected")
self.run_in(self.set_switches, self.args["delay"])
def appd_event(self, event_name, data, kwargs):
self.log_notify("AppDaemon restart detected")
def state_change(self, entity, attribute, old, new, kwargs):
self.log_notify("State change: {} to {}".format(entity, new))
self.device_db[entity] = new
def set_switches(self, kwargs):
self.log_notify("Setting switches")
# Find out what devices are available.
# If we don't know about it initialize, if we do set the switch appropriately
state = self.get_state()
for entity in state:
type, id = entity.split(".")
if type == "input_boolean" or type == "input_select" or type == "input_number" or type == "input_text":
if entity in self.device_db:
if self.device_db[entity] != state[entity]["state"]:
self.log_notify(
"Setting {} to {} (was {})".format(entity, self.device_db[entity], state[entity]["state"])
self.set_state(entity, state=self.device_db[entity])
else:
self.log_notify(
"Adding {}, setting value to current state ({})".format(entity, state[entity]["state"])
self.device_db[entity] = state[entity]["state"]
def log_notify(self, message, level="INFO"):
if "verbose_log" in self.args:
self.log(message)
if "notify" in self.args:
self.notify(message, globals.notify, name=globals.notify)
