I have a script that I want to run in an automation and want to turn it off as soon as the script is done.
I tried doing so inside the automation (script.turn_on then script.turn_off) and in a seperate test at the end of the script (script.turn_off at the end of the script itself)
Neither of the two options is working. How can I switch a script to turn itself off?
I think you should turn the automation off after it gets triggered, not the script.
Do you mind sharing your code?
Have you tried homeassistant.turn_on
and homeassistant.turn_off
The script will turn off as soon as it has completed the last action in the sequence
Of course! See below:
Automation:
- data:
entity_id: script.1521449290108
service: script.turn_on
- data:
entity_id: switch.deurbel
service: switch.turn_off
- data:
service: script.turn_off
alias: Deurbel licht automation
condition:
- after: sunrise
before: sunset
condition: sun
- entity_id: switch.deurbel
platform: state
to: 'on'
The script:
'1521449290108':
alias: Deurbel licht script
sequence:
- data:
message: Er staat iemand voor de deur
service: notify.pushbullet
- data:
entity_id: media_player.homef_2
language: nl
message: Er staat iemand voor de deur. Ga eens snel kijken wie het is!
service: tts.google_say
- data:
entity_id: light.tradfri_bulb_e27_w_opal_1000lm
service: light.turn_on
- wait_template: 1s
- data:
service: light.turn_off
- data:
entitity_id: script.deurbel
- data:
service: homeassistant.turn_off
