Hello everyone,
I have some sockets (from Brennenstuhl) that can be switched over 433 MHz, the sockets have several switches to set a binary code. This binary code can easily be sent by Pilight and the sockets switch accordingly. Is it possible to send the codes directly under Home Assistant? I don’t want to sniff the codes again and write down which code is which.
You can control Pilight, but only if it is not running on the same server. Can’t I simply install the Pilight Hub under Home Assistant?
Best regards!
