I noticed this afternoon that while HA thinks my dimmer switch is on, it has been off most of the day.
Refreshing the browser doesn’t help. It looks like HA is not picking up on changes when switches are manually flipped. Is there a configuration change I need to make, or background task I can run to poll the devices periodically?
What browser are you using? Do you have streaming updates enabled, and what does the switch do?
This sounds like you may need to do a ‘heal’ on your network.
I typically run Safari, but also tested Firefox ESR and also Chrome. I do have streaming updates turned on. I believe I tried doing a ‘heal’ on the zwave network last night.
I think what is happening is if the manual changes happen too quickly, then it can get out of sync.
