Switch telnet - acionamento de reles via telnet
Bom dia!
Tenho o HA instalado em uma VM em meu computador com windows 10, estou tentando fazer com que o HA comunique com um switch chamado MA-1000 da COMM5, ele comunica via telnet.
Do meu computador consigo ativar e desativar os reles utilizando comandos via telnet, porem não consigo pelo HA.
Os comandos para acionar os reles via TELNET são:
SET 1 para ativar o relé 1
e
RESET 1 para desativar o relé 1;
Tentei configurar o HA da seguinte forma:
Example configuration.yaml entry
switch:
platform: telnet
switches:
projector:
resource: 192.168.0.102
port: 5000
command_on: “SET 1”
command_off: “RESET 1”
command_state: “PWR?”
value_template: ‘{{ value == “PWR=01” }}’
O que mais preciso fazer para funcionar?
Obrigado.
Ты правда думаешь, что кто-нибудь ответит тебе португальским письмом? Я предлагаю вам задать свой вопрос по-английски.
Good Morning!
I have HA installed in a VM on my computer with windows 10, I’m trying to get HA to communicate with a switch called MA-1000 from COMM5, it communicates via telnet.
From my computer I can activate and deactivate relays using commands via telnet, but I can not get HA.
The commands for activating the relays via TELNET are:
SET 1 to activate relay 1
and
RESET 1 to disable relay 1;
I tried configuring the HA as follows:
switch:
platform: telnet
switches:
projector:
port: 5000
command_on: “SET 1”
value_template: ‘{{value == “PWR = 01”}}’
What else do I need to do to work?
Thank you.
And if you really want someone to help you please read this:
Without forgetting chapter 11.
