I have a couple of switches that I use for multiple purposes.
For example, I have a switch in my backyard that I use for the swimming pool pump during the summer and in the winter I use it for the Christmas lights.
I already have a input_select set up so I can manually switch between these states, but it would be even nicer if I could make the name of the switch change based on the input_select value.
I see you are using a custom frontend card. My feature request is to support this natively, just like the name of sensors can be templates. So unless someone can show me this can be done natively, my request stands.
