TheStigh
(TheStigh)
May 20, 2019, 4:52pm
1
Hi all,
This post is not identical to the ’ Template switch icon do not change ’
I can see the lock.ytterdor is changing from locked/unlocked in state, so why doesn’t the script below work inside configuration.yaml? Running 0.93.1
The created switch works as expected to lock/unlock the door, but the switch does not have an icon at all at the moment…
switch:
platform: template
switches:
yale_lock:
friendly_name: 'Inngangsdør'
value_template: "{{ is_state('lock.ytterdor', 'locked') }}"
turn_on:
service: lock.lock
entity_id: lock.ytterdor
code: 'XXXXXX'
turn_off:
service: lock.unlock
code: 'XXXXXX'
icon_template: >-
{% if is_state('lock.ytterdor', 'locked') %}
mdi:shield.lock
{% else %}
mdi:shield-open
{% endif %}
petro
(Petro)
May 20, 2019, 5:11pm
2
TheStigh:
mdi:shield.lock
mdi:shield-lock is the correct name.
It’s also possible that the Icon has not been built into home-assistant yet. The icon repository is only updated so-often.
TheStigh
(TheStigh)
May 20, 2019, 6:46pm
3
@petro Uh, typo… But shield-open was not working neither from template.
If I set ‘icon: mdi:shield-lock’ below entity_id inside the card, it shows - does this mean it is built on or not?
How can I check if the icon is built in or not?
petro
(Petro)
May 20, 2019, 6:48pm
4
if it shows up in the interface, it’s built in. If it’s emtpy, it’s a typo or not built in yet.
TheStigh
(TheStigh)
May 20, 2019, 6:51pm
5
@petro , It shows if I do:
- type: custom:button-card
type: entities
title: YTTERDØR
toggle: true
show_header_toggle: false
entities:
- entity: switch.yale_lock
…but not if I set it through the switch template…? I’m lost…
petro
(Petro)
May 20, 2019, 7:29pm
6
And when you remove the line icon: mdi:shield-lock, it doesn’t show anything?
TheStigh
(TheStigh)
May 20, 2019, 9:41pm
7
@petro The type caused it to not work.
Correcting to shield-lock made it work, but the shield-open does not exist.
So I tried to add images instead by setting following, but then there is no images shown…
icon_template: >-
/local/icons/custom/green_shield.png
{% else %}
/local/icons/custom/red_shield.png
{% endif %}
petro
(Petro)
May 20, 2019, 9:53pm
8
icon_template only accepts built in icons. If you use an image you need to use the entity_picture_template field.
TheStigh
(TheStigh)
May 21, 2019, 12:43am
9
@petro You’re amazing, thx!
Perhaps you have a solution for the final part; I’ve read lots of posts regarding changing colors as part of state. I don’t want to change the entity color, I want to change the background color of the card based on state. Optimally, I want to use the code:
animation: blink 2s linear infinite
extra_styles: >
@keyframes blink {
50% {
background: red;
This I want to happen on state ‘unlocked’. Is this achievable without installing CustomUI ?
Using card-modder for this card:
- type: custom:card-modder
card:
type: entities
title: YTTERDØR
toggle: false
entities:
style:
background-image: url("/local/cardbackK.png")
background-repeat: no-repeat
background-color: rgba(50,50,50,0.3)
background-size: 100% 68px
border-radius: 20px
border: solid 1px rgba(100,100,100,0.3)
box-shadow: 3px 3px rgba(0,0,0,0.4)
petro
(Petro)
May 21, 2019, 1:50am
10
the attribute you are looking for is:
--ha-card-background: 'rgba(50,50,50,0.3)'
--ha-card-box-shadow: 'rgba(0,0,0,0.4)'
also i believe this would work too
--paper-card-background-color: 'rgba(50,50,50,0.3)'
TheStigh
(TheStigh)
May 21, 2019, 9:16am
11
@petro But how can I change the background color of a card based on state without CustomUI ? Can I do this as a part of switch template ?
petro
(Petro)
May 21, 2019, 12:10pm
12
Yah, use those attributes in the card-modder. What I provided is 100% separate from CustomUI. I don’t use custom UI.
TheStigh
(TheStigh)
May 21, 2019, 1:29pm
13
@petro May I kindly ask for an example how to change the card backround based on state of a switch or lock?
petro
(Petro)
May 21, 2019, 2:30pm
14
Ah sorry, I kept missing your statement about based on the state of a entity. You can do this without custom UI but it’s just as challenging. You need to add the templating card.
