Switch Template with Boolean Toggle
I have an IR Blaster that doesn’t have an on/off function, just an action. I’m trying to create a switch that will show on/off by input_boolean.toggle but I can’t figure it out
switch:
    switches:
      space_heater:
        value_template: "{{ is_state('input_boolean.ir_heater_onoff', 'on') }}"
        turn_on:
          service: scene.turn_on
            entity_id: scene.xgzu9izdfgwmqqj4
          service: input_boolean.toggle
            entity_id:input_boolean.ir_heater_onoff
        turn_off:
switch:
    switches:
      space_heater:
        turn_on:
          - service: scene.turn_on
          - service: input_boolean.toggle
            entity_id: input_boolean.ir_heater_onoff
        turn_off:
Going crazy here. I got yours above working and used it as a roadmap to build two others. Now only the third one is working (Soundbar Mute Switch). The first two aren’t even showing under my entities, whereas the last one is. Pulling my hair out here!
## IR Blaster Switch heater ##
switch:
    switches:
      space_heater:
        turn_on:
        turn_off:
## TV Power Switch ##
switch:
    switches:
      tv_power_onoff:
        value_template: "{{ is_state('input_boolean.tv_onoff', 'on') }}"
        turn_on:
            entity_id: scene.wx8clarfb9kvriot
            entity_id: input_boolean.tv_onoff
        turn_off:
## Soundbar Mute Switch ##
switch:
    switches:
      soundbar_mute_onoff:
        value_template: "{{ is_state('input_boolean.tv_muted', 'on') }}"
        turn_on:
            entity_id: scene.ytfelxgcqixfnile
            entity_id: input_boolean.tv_muted
        turn_off:
switch:
    switches:
      space_heater:
        turn_on:
        turn_off:
      tv_power_onoff:
        turn_on:
        turn_off:
        turn_on:
        turn_off:
Or, if you want to be a real yaml ninja and save a few lines…
switch:
    switches:
      space_heater:
        turn_on: &space_heater
        turn_off: *space_heater
      tv_power_onoff:
        turn_on: &tv_power
        turn_off: *tv_power
        turn_on: &soundbar
        turn_off: *soundbar
And another solution…Yaml whisperer, indeed! I owe you a beer! Thank you, sir!
What are the & and * operators? I am not familiar w/ them and I cant find them documented anywhere
That’s just shorthand. In other words noting that we’re taking about the sound bar, for example, (&), and then to repeat the above YAML (*), adjusting for off instead of on.
where is this documented?
It’s nothing official
Is it possible to create a button with these functions?
  • button pressed > activates/deactivates a switch entity with 1 sec delay (on/off)
  • for 60 seconds > the button cannot be pressed (inhibited)
  • after 60 seconds > button can be pressed again
