I have a house that 50 years ago was modern, it has latching relays that operate all the lights. I want to automate them and so got a 16 relay board and it works turning lights on and off with a pulse sent.
Problem is we have wall switches as well as using the relay board so the switch never know its state. I got a 16 channel analog input working that tells me via MQTT if it has voltage or not.
Now i need to bring it all together but can’t for the life of me see how it works. I think it will be done with a template switch in /config/configuration.yaml. If anyone could steer me in the correct direction it would be most appreciated.
Listed is the MQTT messages coming in and the switch I tried and failed to get to work:
Coming in:
12/16/2020, 7:57:26 PMnode: 696b6aee.f21344Voltage Input : msg.payload : string[14]
“Sensor 13: OFF”
“Sensor 14: OFF”
“Sensor_15: OFF”
12/16/2020, 7:57:27 PMnode: 696b6aee.f21344Voltage Input : msg.payload : string[13]
“Sensor 0: OFF”
“Sensor 1: OFF”
“Sensor 2: OFF”
And my template:
switch:
switches:
lights4:
friendly_name: “Back Porch Lights”
value_template: “{{ is_state_attr(‘switch.back_porch_lights’, ‘Sensor_15: on’) }}”
turn_on:
service: switch.toggle
entity_id: switch.back_porch_lights
turn_off:
