Herbert01
(Werner)
September 2, 2021, 8:09am
1
Hi there,
I despair again and would appreciate help.
I have the following light group that I want to switch:
# Gruppe Ambientlicht Küche
- platform: group
entities:
- light.iluminize_hk_zd_rgbcct_a_5878befe_level_light_color_on_off
- light.iluminize_hk_zd_rgbcct_a_44ada7fe_level_light_color_on_off
With the following automation I would like to achieve that the lighting group switches automatically. This also works, but not completely:
- id: '1630568859691'
alias: 'Licht Ambient Küche bei Bewegung schalten '
description: ''
- platform: state
entity_id: binary_sensor.lumi_lumi_sensor_motion_aq2_8190c306_ias_zone
to: 'on'
- platform: state
to: 'off'
for: 00:00:10
condition: []
- choose:
- conditions:
- condition: trigger
- condition: state
entity_id: light.ambientlicht_kuche
state: 'off'
- condition: numeric_state
entity_id: sensor.lumi_lumi_sensor_motion_aq2_8190c306_illuminance
below: '1000'
sequence:
- service: light.turn_on
entity_id:
- light.ambientlicht_kuche
data: {}
default:
- service: light.turn_off
entity_id:
mode: single
Two questions / problems:
If one of the lights in the lighting group is switched on and the automation is triggered, the entire lighting group first goes off instead of on.
Where is the error?
How can I switch a light or a group of lights via Lovelace without it going off again due to the automation mentioned above?
Hope you can help me again.
Greetings Werner
Try using this-
- platform: state
to: 'on'
- platform: state
to: 'off'
for: '00:10:00'
condition: []
- choose:
- conditions:
below: '1000'
sequence:
- conditions:
sequence:
default: []
I think it’s because when one of your entities in the group is ON, the group state will be ON. When the sensor is triggered (ON), the first choose
condition where it needs light.ambientlicht_kuche
to be OFF is not satisfied. Therefore, it goes to the default
action.
You can find more information here-
Herbert01
(Werner)
September 2, 2021, 12:10pm
3
Hello and thank you very much.
That works great.
Now there is only my second problem:
I would like to have a switch in the Lovelace that does the following when switched on:
This automation and another automation (name: “LIcht-Arbeitsplatte”) should be switched to inactive for 3 hours and 30 minutes, after which they should be automatically reactivated.
Is that also possible?
Thanks again.
Create an input_boolean
input_boolean:
light_automation_manual_override:
name: Light Automation Manual Override
Create a button card in your lovelace dashboard with tap action of input_boolean.turn_on
targeted to input_boolean. light_automation_manual_override
. When you want to override your automation, you press the button card on your lovelace.
Create an automation to turn off the input_boolean after they are ON for 3.30 hours-
- platform: state
entity_id: input_boolean.light_automation_manual_override
to: 'on'
for: '03:30:00'
condition: []
- service: input_boolean.turn_off
Lastly, on your light automation, add a condition-
condition:
- condition: state
state: 'off'
Herbert01
(Werner)
September 2, 2021, 1:41pm
5
Hi there,
that doesn’t work yet, I probably inserted the condition (input_boolean.lichtautomation_kuche_aus) in the wrong place.
It looks like this for me now:
description: ''
- platform: state
to: 'on'
- platform: state
to: 'off'
for: 00:00:10
condition: []
- choose:
- conditions:
- condition: state
state: 'off'
- condition: state
state: 'off'
entity_id: input_boolean.lichtautomation_kuche_aus
below: '1000'
sequence:
entity_id:
data: {}
default:
entity_id:
mode: single
- id: '1630589206080'
alias: Lichtautomation Küche aus
description: Helfer (input_boolean.lichtautomation_kuche_aus) wird nach Zeit ausgeschalten
- platform: state
to: 'on'
for: 00:10:00
condition: []
mode: single
Or is it because I went into the room, the light went on automatically and only then did I press the Boolean switch?
Greetings Werner
- platform: state
to: 'on'
- platform: state
to: 'off'
for: '00:10:00'
condition:
- condition: state
state: 'off'
- choose:
- conditions:
below: '1000'
sequence:
- conditions:
sequence:
default: []
Herbert01
(Werner)
September 2, 2021, 2:40pm
7
I just can not manage it.
With this code:
description: ''
- platform: state
to: 'on'
- platform: state
to: 'off'
for: '00:10:00'
condition:
- condition: state
state: 'off'
- choose:
- conditions:
below: '1000'
sequence:
- conditions:
sequence:
default: []
I get the following error message:
end of the stream or a document separator is expected at line 421, column 1:
And is it correct with that new code
default:
entity_id:
by
default: []
is replaced?
Note: I have given my input boolean the following name:
I’m sorry, I’m a complete beginner.
Greetings Werner
Herbert01
(Werner)
September 2, 2021, 2:43pm
8
A moment please. The error message suddenly disappeared. I have to test, but my wife is out in the kitchen
If you want to copy my code, go to Automation Editor UI —> Create Automation —> On the right hand side there are three dots —> Edit in YAML.
Herbert01:
default: []
Correct. I moved it under the choose action by specifying the condition trigger OFF.
Herbert01
(Werner)
September 2, 2021, 3:35pm
10
Hi there,
I have now inserted it via the user interface.
The automation works too.
But although the helper “input_boolean.lichtautomation_kuche_aus” is switched on, the light goes out.
The automation is considered not to be stopped.
I do not understand that.
Greetings Werner
Can you post here your exact code?
Input Boolean
Automation
Herbert01
(Werner)
September 2, 2021, 4:07pm
12
I am very sorry.
The problem was that I hadn’t turned off the old automation.
It couldn’t work there.
I still have to test it a bit, but I think everything works.
Thanks again. Without people like you, I wouldn’t have a smart home.
Thanks !!!
Greetings Werner
