Hello
I see there’s been some threads on this topic, however I’m not sure how to go about making an entity change and am turning to the group for help.
I have a “TopGreener Dimmer” wall switch running Tasmota 10.1.0. It shows up in Home Assistant as the entity switch.basement_stairs. I believe in order to use the dimmer feature I need to change the entity from “switch.basement_stairs” to “light.basement_stairs” then install the appropriate card to control the on / off and dimmer functions.
Can someone please guide me as to how to do this? Is it done within Tasmota, a special entry into my configuration.yaml file or where / how?
Thanks in advance for any help that can be provided.
